HP 840 g10 bios
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I noticed there's a lot of unlock request for this model HP EliteBook 840 14 inch G10
The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU and put your original DMI.
frequently asked questions:
can i use this to my HP EliteBook 840 14 inch G10 - Yes
I've run the utility but it just sajus"Wrong chip. Try reading and unlocking 16mb chip!"
I cannot install new OS as it stands. Not sure what I'm doing wrong here. Thanks in advance!Comment
I've read through all the guides/documentation that I've been directed to, but I cannot figure out how to eliminate the bios password on this laptop and the seller claims they do not have any record of what the password is.
post your bios here maybe you find your unlockComment
How can I take a dump of my bios without being able to access it directly?Comment
Hi, after applying post 120 the password prompts for F9, F11 and F12 were disabled, but unfortunately not F10. After flashing both chips (and re-reading and verifying against supplied bins) the HP Elitebook 840 G10 went through its normal few reboots, but before I got the opportunity to get to a point where I could press F10 to set factory defaults, I was presented with "BIOS Identity Data Recovered: The BIOS has recovered its identity from the Embedded Controller due to data mismatch"
Anyway, please see attached dumps. Hopefully they can help identify a resolution
Model: HP EliteBook 840 14 inch G10 Notebook PC
S/N: 5CG3481C3F
ProdID: 6V5Y3AV
MB: 6050A3452701-MB-A01
S/N: 5CG3481C3F
ProdID: 6V5Y3AV
https://www.badcaps.net/forum/troubl...29#post3584829Comment
Attached FilesComment
Yes, also re-read both main and EC to verify again against bins. I have tried another two times today with same result.
After the "Recovery" screen I also tried just reflashing the EC. Password still required for F10Comment
dont try anymore, replace super I/O with other which no password. what's your mainboard super I/O?Comment
Managed to solve the issue. I modified your EC.bin provided in post # 120 and cleared NVRAM ActiveRegn.
This time, instead of the EC recovery screen, it threw the "Entering MPM" and was able to F10.
Password now gone. You are a legend rex98.
Probably best to verify attached before use.
Probably best to verify attached before use.Comment
thank you Duckie-Electronics you give us a valuable info about this. i think this method would work in G11
I'll repeat on another 840 G10 in the next few days.Comment
And the main , do you use the one from post 120 !Comment
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by macabookHello everyone,
07-24-2025, 02:17 PM -
Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
Asus S533F serial L6N0CV190141266
Current BIOS firmware version is X521FA-305
Thank you!...-
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
- Loading...
