Can someone remove the setup password from my bios so i can clean install windows? Thanks in advance
					Panasonic Toughbook FZ-55
Read the updated rules, post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
tryAttached FilesComment
goodnight
Could you remove the boot password from the bios please?
model :FZ-55-C9-00VM
SERIAL NUMBER: 1ATTA06968
thank you very much I really appreciate it​Attached FilesComment
Password removedAttached Files↵
​https://www.badcaps.net/donateComment
post S/N, full name and model, motherboard model,post the original contents of the bios chip..etc.
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHow​Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
I have managed to extract the the content of the bios chip that is locked.
The Laptop model is:
FZ-55A03NTE
Serial NO.
OITCA67271
Can you please help me, in removing the password?Attached FilesComment
O is 0 (zero) - from serial
TryAttached FilesLast edited by volinakis; 02-07-2025, 05:59 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
The Laptop model is: FZ-55A-00HT4
Serial NO. 9LTCA06062
The bios chip is locked. Can anyone help me pleaseAttached FilesI can't seem to find much about working on these units yet or information about working on the BIOS. Thought I would start a thread about the FZ-55 Toughbook. I'm in the process of dissecting one currently. The Main PCB is model FM182mk1 I was able to read both the front and back MXIC MX25V8035F chips however I don't have aComment
TryAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi
I have a Panasonic, it still turns on but no picture, please help me fix it.
Model: FZ-55FZ006VM
SERIAL NUMBER: 2GTTA11699
Model: FM182mk2 main PCBAttached FilesComment
Please remove the bios password.
Model: FZ-55C2
SN 0DTTA24382
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
			by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
							Channel: BIOS Requests ONLY!
			by AquaMan UaHello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....2 Photos -
			by eukalHello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So... -
			by Nedim MerdanDoes anyone have the schematic for toughbook cf-d1 mk1 motherboard model is DL3UP1969CAA thanks in advance
12-07-2024, 02:22 PM -
			I've been working on this awful project with a Panasonic FZ-55, basically I'm trying to intercept the eDP signal from the main board, and replace it with my own eDP signal connected from an lcd driver. The problem is, for some reason the 30 pin ribbon pinout is really unusual and not playing nice with my LCD controller. Long story short, I managed to fuck up my board and pull off some pads on the eDP out port, I'm hoping to find either another eDP out source somewhere else on the laptop, or figure out this goddamn pin layout so I can just replace the whole native display complex with my controller...
 - Loading...
