packardbell easy note bios dump
  • asliyucegsm
    • Jun 2011
    • 352
    • Turkiye
    my friend
    mainboard. new75 la-5911p rev.1.0
    bios dump
    25f16
    thanks
  • alexnavin
    • Jun 2015
    • 46
    • Seattle
    Re: packardbell easy note bios dump
    Needed bios dump, please
    • samanthban
      • Feb 2014
      • 252
      • Sri lanka
      back up and try this
      sigpic
      • canali
        • Oct 2014
        • 196
        • turkey
        Friends hello packard bell If you have a TE11-hr-111TK bios dump
        • sourcebf
          • Jul 2016
          • 435
          • N/A
          Try this dump
          • sourcebf
            • Jul 2016
            • 435
            • N/A
            your board number please?
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              here...
              this bios is identical with acer la-7912...
              for acer la-7912 bios, you can try search another post in this forum..
              • wzamoyski
                • Mar 2022
                • 28
                • Poland
                Packard Bell PEW96
                EasyNote TK81-SB-022GE
                Motherboard: NEW75 LA-591P Rev. 1.0
                CPU: AMD Athlon II
                GPU: 216-0174007
                NB: 216-0752001
                SB: 218-0697014
                ENE KB926QF
                Issue: black screen, no picture
                  • 22424
                  Originally posted by wzamoyski
                  Packard Bell PEW96
                  post the laptop serial number
                  • wzamoyski
                    • Mar 2022
                    • 28
                    • Poland
                    S/N: LXBQC020170430AE5C1601
                    SNID: 04304463616
                      • 22424
                      SNID: 04304463616
                      have you tried the bios at post 3
                      • wzamoyski
                        • Mar 2022
                        • 28
                        • Poland
                        Yes. But not working.
                        • wzamoyski
                          • Mar 2022
                          • 28
                          • Poland
                          Old bios working fine. Problem is with NB 216-0752001. After reflow laptop start.
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
                          • mkdj
                            by mkdj
                            Dear all,
                            10-19-2025, 04:41 AM
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • haitham sharabati
                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                            by haitham sharabati
                            Hello engineers 😀,
                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                            🔧 Device Info:
                            - Model: HP 15-da2007ne
                            - Product Number: 8XF55EA#ABV
                            - Serial Number: CND0338P0D
                            - CPU: Intel Celeron N4000
                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                            💀 Problem:😅
                            - Device shows “Administrator Password”...
                            08-07-2025, 04:54 AM
                          • Citymin
                            by Citymin
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
