packardbell easy note bios dump
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    my friend
    mainboard. new75 la-5911p rev.1.0
    bios dump
    25f16
    thanks
  • alexnavin
    • Jun 2015
    • 46
    • Seattle
    Re: packardbell easy note bios dump
    Needed bios dump, please
    • samanthban
      • Feb 2014
      • 253
      • Sri lanka
      back up and try this
      sigpic
      • canali
        • Oct 2014
        • 191
        • turkey
        Friends hello packard bell If you have a TE11-hr-111TK bios dump
        • sourcebf
          • Jul 2016
          • 431
          • N/A
          Try this dump
          • sourcebf
            • Jul 2016
            • 431
            • N/A
            your board number please?
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              here...
              this bios is identical with acer la-7912...
              for acer la-7912 bios, you can try search another post in this forum..
              • wzamoyski
                • Mar 2022
                • 27
                • Poland
                Packard Bell PEW96
                EasyNote TK81-SB-022GE
                Motherboard: NEW75 LA-591P Rev. 1.0
                CPU: AMD Athlon II
                GPU: 216-0174007
                NB: 216-0752001
                SB: 218-0697014
                ENE KB926QF
                Issue: black screen, no picture
                  • 20619
                  Originally posted by wzamoyski
                  Packard Bell PEW96
                  post the laptop serial number
                  • wzamoyski
                    • Mar 2022
                    • 27
                    • Poland
                    S/N: LXBQC020170430AE5C1601
                    SNID: 04304463616
                      • 20619
                      SNID: 04304463616
                      have you tried the bios at post 3
                      • wzamoyski
                        • Mar 2022
                        • 27
                        • Poland
                        Yes. But not working.
                        • wzamoyski
                          • Mar 2022
                          • 27
                          • Poland
                          Old bios working fine. Problem is with NB 216-0752001. After reflow laptop start.
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • grimacelord
                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                            by grimacelord
                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                            Motherboard model number: DA0PAMB46A1 REV: A
                            Secondary motherboard model number: 0PAB
                            SKU: 685K4UA
                            Serial number is: 5CD3223BJP
                            Recently reflashed this laptop with latest BIOS and once...
                            05-07-2024, 08:06 AM
                          • DynaxSC
                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                            by DynaxSC
                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                            11-06-2022, 05:22 PM
                          • TacticalFahrrad
                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                            by TacticalFahrrad
                            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                            06-30-2025, 04:09 AM
