ASUS TUF FX516PM-HN023T - bios
  • Gigabyte_PL
    • Dec 2021
    • 36
    • Poland
    I am looking for a BIOS for ASUS TUF FX516PM-HN023T. Laptop has a problem with stable voltage and does not want to start. All resistances are OK.
    Thank you in advance.​
  • Gcs_rma
    Banned
    • Dec 2023
    • 108
    • N/A
    Serila number?
    • mrdphu
      • Jan 2016
      • 8
      • Việt Nam
      you can try ASUS TUF Gaming F15 FX506LH-F1.309 bios
      • Gigabyte_PL
        • Dec 2021
        • 36
        • Poland
        Originally posted by Gcs_rma
        Serila number?
        If you have clear BIOS please share me it for test. If all will be fine I add SN to .bin file.
      • Gigabyte_PL
        • Dec 2021
        • 36
        • Poland
        Dump in attached file​
          SMDFlea commented
          Editing a comment
          Where is the serial number that you`ve been asked to post ????
      • marcin.jakubowicz87
        • Apr 2018
        • 14
        • Poland
        I am looking for a BIOS for ASUS TUF FX516PM-HN023T SN:M2NRKD010646075 black scr
        old dump
        • Gcs_rma
          Banned
          • Dec 2023
          • 108
          • N/A
          old dump
          FX516PM
            • 20309
            old dump
            Bios + DMI .Try it and give
              • Apr 2018
              • 14
              • Poland
              Thank you for your help SMDFlea , but the screen is still black, I think it may not be the BIOS
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • lrouw84
                by lrouw84
                Hi there,
                01-28-2023, 01:31 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
