UNOWHY Y13 2022 BIOS password
  • sassan
    • Apr 2014
    • 65
    • France
    #141
    Originally posted by shiyab
    hi try
    hello i tried it same as the previous bin ,no display,blinks a couple of times and powers off.
    • volinakis
      • Jan 2021
      • 2733
      • N/A
      #142
      Originally posted by sassan
      hi,i tried no display!,thank You
      check soldering
      • sassan
        • Apr 2014
        • 65
        • France
        #143
        Originally posted by volinakis
        check soldering
        i used pogo pins to read and write the chip.i flashed the original file back same problem power button blinks a couple of time then turns off,i tried a bin file downloaded from this thread and i got defferent behavor,it turns on no blinking but no display.
        so maybe when i read it the first time the bin file that i saved was corrupted.can you please fix it?
        Thank You for Your Help
        • volinakis
          • Jan 2021
          • 2733
          • N/A
          #144
          that's why is recommended to read 2-3 times chipset and compare results.
          try this one
          • sassan
            • Apr 2014
            • 65
            • France
            #145
            try this one
            You are a life Saver,Your file is working.Thank you so much.
            • volinakis
              • Jan 2021
              • 2733
              • N/A
              #146
              you are welcome
              • Iboun Housseini
                • Sep 2022
                • 32
                • Mali
                #147
                Hello, I need help to unlock a UNOWHY
                MB : MB: EM_IG116_200B_ENE_F_V1.0
                N° IFP128027712
                Model :Y13G011S4EI
                • shiyab
                  • Sep 2023
                  • 1479
                  • india
                  #148
                  N° IFP128027712
                  Model :Y13G011S4EI
                  hi try
                  • Iboun Housseini
                    • Sep 2022
                    • 32
                    • Mali
                    #149
                    hi try
                    Thans a lot, it is unlocked
