UNOWHY Y13 2022 BIOS password
  • volinakis
    • Jan 2021
    • 2874
    • N/A
    Originally posted by atmega4
    i need unlock unowhy Y13 2022 please
    Production year : 2022 June
    Model : Y13G012S4EI
    Motherboard : EM_IG116_200b_ene_TI_V1.0​
    this is a good one, rex98 missed a spot ...
    • atmega4
      • Jun 2017
      • 36
      • oran
      working fine tanks You Brother rex98 a use your dump and you volinakis​ thank you.
      • ddhlawi
        • Feb 2017
        • 169
        • algerian
        I have UNOWHY Y13 (2022) BIOS PASSWORD
        MODEL: Y13G012S4EI
        M.B: EM_IG116_200B_ENE_TI_V1.0
        • minhdigital
          • Nov 2022
          • 765
          • Vietnam
          MODEL: Y13G012S4EI
          Send to you, try ( if it works, thanks for @volinakis​ solution )
          • ddhlawi
            • Feb 2017
            • 169
            • algerian
            Thanks.thanks.thanks
            • atmega4
              • Jun 2017
              • 36
              • oran
              #26
              please i need unlock BIOS unowhy Y13 2021
              Production year : Aout 2021
              Model : Y13G011S4EI
              Motherboard : EM_IG116_200b_ene_F_V1.0​
              • fradoti
                • May 2024
                • FRANCE
                #27
                I have this laptop model:
                Laptop: UNOWHY Y13 2022
                Production: Mai 2022
                Motheboard: EM_IG116_200B_ENE_TI_V1.0
                Serial: IFP22089758
                I tried to re-write BIOS but it didn't work. I want to get rid of the Admin password and be able to install Linux on it.
                I took out the EPROM, I wrote it, and put it back in.
                I tested two BIOS versions :
                1. Bios-nopass.BIN.zip by "volinakis"
                2. NOPASS.bin.zip by "volinakis"
                Unfortunately I don't have any error messages to go by.
                When I power on the laptop it simply powers off right away if using "Bios-nopass.BIN.zip" 1 or blinks a couple of times and powers off when using "NOPASS.bin.zip."
                The screen remains unlit in both cases.
                What should I try next?
                I compared my original version and the ones I downloaded with Beyond Compare and I can tell there are big differences.
                Unfortunately I don't know what I should be looking for.
                Any help would be very much appreciated.
                Regards,
                Tudor​
                • minhdigital
                  • Nov 2022
                  • 765
                  • Vietnam
                  #28
                  Serial: IFP22089758
                  Regards,
                  Tudor​
                  Send to you
                  • fradoti
                    • May 2024
                    • FRANCE
                    #29
                    Send to you
                    Thank you for answering so fast! It's very appreciated. I'll test it and get back to you.
                    Regards,
                    Tudor
                    • volinakis
                      • Jan 2021
                      • 2874
                      • N/A
                      #30
                      Serial: IFP22089758
                      Regards,
                      Tudor​
                      you can't use bios from another laptop, your original bios has to be modified.
                      • fradoti
                        • May 2024
                        • FRANCE
                        #31
                        For volinakis
                        Thankfully somebody took pity on me and did the work in my place.
                        I'm too old for this. I kind of understand they want some protection in place, but then the providers of the machines should offer software installation services and such, otherwise it's just an internet connected brick. A smart brick, as it were.
                        For minhdigital
                        I just wanted to let you know that I finally tried it. Almost screwed the board soldering and desoldering so many times, but all's well that ends well.
                        It works perfectly fine. Thank you for your help.
                        In case that it matters to you: I powered it up and for about 4 seconds it was running but not displaying anything on the screen. Then it restarted itself and I could access the BIOS.
                        Now on to the Linux install
                        • sizar00740
                          • Jun 2022
                          • 13
                          • ALGERIA
                          #32
                          PLEASE I NEED TO UNLOCK Y13 BIOS PASSWORD
                          Model : Y13G012S4EI
                          • Bilal@pc
                            • Jun 2021
                            • 44
                            • Algeria
                            #33
                            Production year : 2022 May
                            Model : Y13G012S4EI
                            Motherboard : EM_IG116_200B_ENE_TI_V1.0​
                            • rex98
                              • Feb 2023
                              • 1293
                              • Mandaue CEBU, Philippines
                              #34
                              Model : Y13G012S4EI
                              try
                              • rex98
                                • Feb 2023
                                • 1293
                                #35
                                Model : Y13G012S4EI
                                try
                                • sizar00740
                                  • Jun 2022
                                  • 13
                                  • ALGERIA
                                  #36
                                  Originally posted by rex98
                                  try
                                  still ask for password
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12330
                                    #37
                                    KKK
                                    • minhdigital
                                      • Nov 2022
                                      • 765
                                      • Vietnam
                                      #38
                                      Send to you, try ( if it works, thanks for @volinakis solution )​
                                      • Zakaria Benatia
                                        • Jun 2024
                                        • algeria
                                        #39
                                        Pls i need unlock for this Y13 i bought on ebay and got scammed.
                                        Production year : April 2022
                                        Model : Y13G012S4EI
                                        • volinakis
                                          • Jan 2021
                                          • 2874
                                          • N/A
                                          #40
                                          Model : Y13G012S4EI
                                          try
