UNOWHY Y13 2022 BIOS password
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
i used pogo pins to read and write the chip.i flashed the original file back same problem power button blinks a couple of time then turns off,i tried a bin file downloaded from this thread and i got defferent behavor,it turns on no blinking but no display.
so maybe when i read it the first time the bin file that i saved was corrupted.can you please fix it?
Thank You for Your HelpComment
that's why is recommended to read 2-3 times chipset and compare results.
try this oneAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hello, I need help to unlock a UNOWHY
MB : MB: EM_IG116_200B_ENE_F_V1.0
N° IFP128027712
Model :Y13G011S4EI
Attached FilesComment
hi tryAttached FilesComment
Post the serial number, IFPxxxxxxOriginally posted by Sakihousei need unlock unowhy Y13 2022 please
Production year : 2022 June
Model : Y13G012S4EI
Motherboard : EM_IG116_200b_ene_TI_V1.0Comment
Model : Y13G012S4EI
serial: IFP224106458
My sorry bossAttached FilesComment
UnlockedAttached Files↵
https://www.badcaps.net/donateComment
Every donation made will go towards server fees and maintenance costs.Comment
by BlackVisorRedmiBook Pro 1542022 6800H
SKU: TM2113-39463
Model Number: RMA2204-AB
CMIIT ID: 2022AP1835
SN: 39463/22WD01355
BIOS version: RMARB5B0P1010 20230628
1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...-
Channel: BIOS Requests ONLY!
01-14-2024, 06:35 AM -
by maamar-tdjHellobrothers!
I need to remove the BIOS password.
I attached the bios dump file.
Laptop: UNOWHY Y13 2022
Motheboard: EM_IG116_200B_ENE_TI_V1.0
Serial: IFP230136920
Thanks in advance!...-
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
- Loading...
