looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
  • zlr8r
    • Feb 2023
    • 55
    looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
    cheers
    Dell Inspiron 17 (7786) Laptop
    Service Tag: 5J0NHT2
    Bios: 1.9.0
    MOBO: RO 15 17 WHL 2GB MB / 18706-2
    Attached;
    1. My saved bios using a programmer
    2. Dells Bios updater .exe (v1.16)
    3. Dells Bios recovery file
    4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
    5. Image of ME Analyzer result from my saved bios file.
    There is a glitch stopping me adding attachments to this post, so i have added them further below.
  • kalilinux25
    • Mar 2018
    • 2069
    • ZAMBOANGA SIBUGAY
    Originally posted by zlr8r
    looking for fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, So I can compare it with my own bios to check for corruption.
    cheers
    please provide the full details specially the service tag
      • 20412
      cheers
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
      • Provide a BIOS/EC dump if possible
      • Attach files directly to your post instead of linking to external websites
      • zlr8r
        • Feb 2023
        • 55
        ? tried to update OP, but my edits arent saving nor are my attachments ?.
        They vanish after is press Save ? also after editing the post, other text is being wiped ? whats happening ? Pressing save on an edited post does not save changes made ?
        [update] 15 mins later the forum started working again ... ? Ok, will try to update again OP.
        • Admin
          • Oct 2003
          • 5334
          • United Kingdom
          possibly a cache issue
          • zlr8r
            • Feb 2023
            • 55
            thought that and cleared history in Chrome, same happened again and again. Then site suddenly started working again after 15 mins?, it let me edit text but now isnt saving my attachments ?
            Can you see any attachments on the OP at the top of this page ?
            Admin, is there a glitch in the Matrix blocking my attachments ? its weird, because i can see the jpg image in my OP, but when i try and edit the post, its not there? And none of the .zip attachments I try to add will save ? (tried both Chrome and Firefox, same result) please advise
            • zlr8r
              • Feb 2023
              • 55
              You MUST:
              Hi, I am having a problem uploading any attachments to my post ?
              When i edit the post, I see the option to attach file, I select a file from my computer. I repeat this for the remaining attachments. I then hit SAVE. After that , the post remains unmodified and no attachments are present ? (also tried using the "insert" option, same result. Am I doing something wrong ?
              • Attach files directly to your post instead of linking to external websites - cannot do at present due to problem above?
              please advise cheers
              sample;
              Click image for larger version  Name:	Screenshot_1.png Views:	0 Size:	51.2 KB ID:	3165288
                • 20412
                Attach the files to your next post,if that doesn`t work rename the attachment to some other name and see if that works.
                • zlr8r
                  • Feb 2023
                  • 55
                  since I cannot add attachments to the original OP, ill try adding them here;
                  • hotcrossedbuns999
                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                    by hotcrossedbuns999
                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                    3. I could only locate two chips that look like bios chips. Could someone verify this
                    01-03-2025, 12:32 PM
                  • what_1282105
                    Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                    by what_1282105
                    Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                    02-14-2025, 07:27 PM
                  • bschwand
                    ASUS N550JK laptop reboots after 30 minute, BIOS extracted invalid...
                    by bschwand
                    as subject line says, I have a laptop that reboots after 30 minutes. Investigation leads me to believe that is due to intel ME as it happens everytime after 30 minute from boot, it just turns off, no overheating, nothing weird.
                    I found a lot of information about cleaning ME like this https://winraid.level1techs.com/t/gu...lization/31277 and this https://github.com/corna/me_cleaner
                    Anyway, first step is to dump the bios. I found the Winbond W25Q64FV chip on the motherboard, dumped it with flashrom over...
                    05-22-2024, 02:48 AM
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
                  • traxformania
                    TONGFANG "GM7TG7P" Bios Password Problem?
                    by traxformania
                    I tried :
                    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                    11-15-2023, 07:32 AM
