Mac upgrading from Ventura to Sonoma with activation bypass
  • kevingill
    • Jun 2013
    • 152
    • England
    I've got a MacBook Air 2018 that was activation locked.
    I've used an online service to bypass the activation and was able to sign in to iCloud. If you power off the MacBook and restart, it will be activation locked again.
    However, I've just upgraded it from Ventura to Sonoma and after completion, the activation screen came up.
    To my surprise, this prompts for my Apple email ID and password.
    Once entered, the MacBook is fully activated and powering off and on works absolutely fine.
    Can someone else try this to see if it works for them too please?
  • curiositymaster
    • Apr 2021
    • 45
    • Nigeria
    I think the previous user removed activation-lock.
    • toshyou
      • Jan 2023
      • 35
      • singapore
      Probably?
      • toshyou
        • Jan 2023
        • 35
        • singapore
        Online where? Checkmate?
        • curiositymaster
          • Apr 2021
          • 45
          • Nigeria
          From their Apple account I guess
          • tobeend
            Bypass mdm macbook m2 ventura
            by tobeend
            1. RESET MACOS WITH IPSW
            a. Power off MacBook, press and hold the power button to enter Recovery
            b. Open Disk Utility, remove Macintosh HD
            c. Reboot, connect to the network to Activate Mac.
            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
            e. Release the other keys, but keep holding the Power key for another 10 seconds
            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
            05-26-2023, 07:18 AM
          • oxonater
            Apple MacBook Pro A2141 16" IC BYPASS
            by oxonater
            Hi everyone hope all are well
            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
            I suppose it's worth noting googling the part package brings up various...
            10-23-2024, 11:21 PM
          • harounHD
            Macbook a1989 and a2338 icloud bypass
            by harounHD
            Is there a solution for Macbook a1989 and a2338 icloud bypass , i saw a video on youtube of someone using a bootable usb to unlock it
            02-01-2025, 03:23 AM
          • Stephen
            MacBook Pro 16” 2019 Boots installs os Catalina but won’t install Ventura or lower.
            by Stephen
            So got an issue, did a DFU recovery for a 16” we have.
            It will install Catalina from internet recovery perfectly fine.
            Tried upgrading to Ventura, no bueno, so created bootable installer of Ventura. Nothing it just gets hung up at the half way point for over 24 hours.
            No water damage on board. Board is clean. Any idea why this is?
            All ports works
            Did a DFU RECOVERY AND RESTORE, twice with success and successfully reinstalled Catalina. But it seems it won't install anything higher. Any suggestions would be great.
            05-19-2023, 10:53 AM
          • mitchw
            M1 MacBook Air 820-02016 possible to swap ROMs to unlock a locked board?
            by mitchw
            I have a liquid damaged 820-02016 that has a 1-2mm wide hole in the PCB caused by a burned capacitor. The PPBUS_VON is shorted. I think the board is 100% gone, I tried grinding off the burned PCB material with no avail, the board is burned almost through to the other side.
            But, I can get a fully working iCloud locked mainboard for very cheap.
            As far as I have seen, there are only two ROM chips on the board, the TBT ROM and main flash.
            Is it possible to transfer these two ROMs from the bad board to the good locked one and "unlock" the good...
            09-07-2023, 06:25 PM
