asus X450JB bios fix request
  • jokophp
    • Dec 2017
    • 39
    • indonesia
    Motherboard asus X450JB kode SV41 JN MB 13320-1
    CPU intel core i7-4720HQ
    GPU nvidia 940M
    PCH intel HM86
    if with X450JN bios, run windows normal but can't install nvidia gpu driver, not detect gpu chip.
    if with X450JB bios, run windows 30 minutes die/shutdown, install nvidia gpu driver succesfully.
    please help me, sir...
  • hoaca388
    Badcaps
    • Jan 2022
    • 11683
    GPU nvidia 940M
    PCH intel HM86
    Serial number ?
    • jokophp
      • Dec 2017
      • 39
      • indonesia
      E3n0wu02813211a
      • jokophp
        • Dec 2017
        • 39
        • indonesia
        GPU nvidia 940M
        PCH intel HM86
        but, this is replacement motherboard, and I found it in a state where the BIOS had been reprogrammed.
        • kalilinux25
          • Mar 2018
          • 2084
          • ZAMBOANGA SIBUGAY
          The bios you provide is fresh and shoukld work without issue possible you need to look for other issue
          • jokophp
            jokophp commented
            Editing a comment
            Thank you for your response sir.
          • 20768
          Post a picture of the long white barcode sticker on the ram slot.
          • jokophp
            jokophp commented
            Editing a comment
            yes sir, i've uploaded it.
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          TRY AGAIN A NEW ONE
          • jokophp
            jokophp commented
            Editing a comment
            Thank you for your response sir, i will try it.
        • jokophp
          • Dec 2017
          • 39
          • indonesia
          mobo barcode.
          • odie novega
            • May 2016
            • 4
            • Indonesia
            same problem,
            please repair
            x450jb slow respon
          • odie novega
            • May 2016
            • 4
            • Indonesia
            Originally posted by odie novega
            same problem,
            please repair
            x450jb slow respon
            thank for response sir,
            can you help me
            serial number F1N0WU01606501C
              • 20768
              can you help me
              Try this bios.
              • odie novega
                • May 2016
                • 4
                • Indonesia
                sorry sir,
                laptop shuting down after 15-30m,
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
