Compaq presario v3000 WOnt boot after bios screen
  • Lankitha
    • Aug 2012
    • Sri Lanka
    I have a Compaq presario v3000, when the battery is in the computer wont boot with the power button, but when the power is connected it will boot by it self, can go to bios pressing F10, bios is working fine, after i save and exit. only flashing cursor appears. nothing happen after that. And the when i long press the power button i wont shut down. When i remove the battery and connect the charger the power button works (only to turn on, long press shut down wont work), but even in this scenario the computer wont pass the bios screen. And when i press quickplay button. it is turning on also. HELP
  • newbiesat
    • Dec 2012
    • 25
    • usa
    Re: Compaq presario v3000 WOnt boot after bios screen
    Try to re-seat the RAMs without the battery insert to see what happen.
    • Lankitha
      • Aug 2012
      • Sri Lanka
      Already tried. didnt work
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Blinking cursor= Corrupted MBR.
        (And the BIOS is still trying to use it.)
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          did you try a known good hdd ? if still fails, flash the bios. it should work.
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • q2v5
            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
            by q2v5
            Lenovo T480s
            Model 20L8-S3TE00
            Board ET481-U10
            Chip MX25L12873F
            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
            08-15-2024, 10:40 PM
          • Neddsme
            Bios partially corrupted somehow and now warm boot doesn't work which is critical
            by Neddsme
            Hie.
            I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
            Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
            I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
            I managed to run Windows troubleshooting and...
            02-04-2022, 05:57 AM
          • Max029
            Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
            by Max029
            I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
            I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
            TY,
            08-18-2024, 08:28 PM
          • futadmytro
            Asus g713qm-es94 stuck on boot bios problem
            by futadmytro
            sn^M4NRKD02753616E
            MB- g533-6050a3250201-MB-A03
            Stuck on boot after ROG logo, did not enter to bios
            In flash bios , laprop boot but have video issue
            orig bios...
            06-25-2025, 08:07 AM
