hp dv5000 series bios problem
  • thesloc
    Banned
    • Dec 2011
    • 587
    PXE-E61: Media test failure, check cable
    PXE-061: Media test failure, check cable
    PXE-M0F: Exiting Intel PXE ROM
    I can access bios and change the booting order (it think it's booting from a network according to error) but to no avail.
    I'm guessing the problem is hardware-based or something.
    Anybody?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: hp dv5000 series bios problem
    Could be the southbridge, apparently it does not see the hard drive and DVD. Does it boot from USB?
    A working TV? How boring!
    • mockingbird
      • Dec 2008
      • 5484
      Disable boot with PXE... They used to use that for computers that would boot of a NIC's rom which could be flashed...
      I guess the question is then why isn't it booting from the HDD? Plug the HDD into a desktop motherboard and see if it is detected by the BIOS.
      • thesloc
        Banned
        • Dec 2011
        • 587
        I can't disable the Network boot, only change the priority of the boot sequence (I set the network to last). NO dice. Or maybe I misunderstood you.
        Yeah, my second guess is that it might have to do with the hard drive. I shall test this and report back.
        • thesloc
          Banned
          • Dec 2011
          • 587
          Ah, interesting. These HPs are plagued with GPU/Bridge defects. It might even require a quick reflow.
          I haven't tried USB booting -- but like I said, it can't boot from anything. It goes straight to that error right after the HP bios logo.
          • thesloc
            Banned
            • Dec 2011
            • 587
            OK -- update.
            Turns out the hard drive is bad. So I swapped it out.
            The next problem is that when I start and try to do a Windows (XP) CD installation it automatically shuts down right after the first step of the process is loaded. So right after "Windows is starting installation" then it does so without warning or anything. Just shuts down.
            This happens also with 7.
            Any other way of installing the OS on a laptop that doesn't support USB booting?
            • mockingbird
              • Dec 2008
              • 5484
              I think your Northbridge has bit the dust, in a manner of speaking. Symptom of G8x, G9x IGP failure is random reboot or screen corruption when attempting to use higher resolutions. I think that when the graphical part of the installation starts, the IGP flips out.
              You can try to reflow, it might help. Flux it up nice and good.
              • thesloc
                Banned
                • Dec 2011
                • 587
                OK, if there's any other solution I'm all ears on this one.
                Bios is Phoenix F.42. Laptop's an HP dv5224nr.
                • mockingbird
                  • Dec 2008
                  • 5484
                  Spec sheets states:
                  "ATI RADEON XPRESS 200M IGP"
                  So this is not an nVidia chipset, but the 200M has also been known to require reflowing. I don't think that's the problem.
                  Could the automatic shutdown have something to do with heat? What kind of adapter are you using?
                  • thesloc
                    Banned
                    • Dec 2011
                    • 587
                    I'm using the standard HP adapter 18.5V that came with it.
                    but don't u think it's weird that right after, BEFORE the GUI interface, it shutdowns with no warning? I think this is before it loads anything onto the hd.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      With both the XP and 7 installation media? Yes, very odd. Are these install discs vanilla MSDN ISOs or are they modified with slipstreaming or with driver packs?
                      • thesloc
                        Banned
                        • Dec 2011
                        • 587
                        They are standard ISOs, freshly burned.
                        Any chance this is a dvd drive problem?
                        Wish I had extra hardware to test this out !
                        • heavymachines
                          • Mar 2011
                          • 1028
                          sounds like it may be getting hot,blow the heat sink out it may be so plugged with dust you won't feel much heat exiting out ,,,check after blowing out with flashlight in intake area to make sure big clumps are not lodging fan , sometimes you can use toothpicks to fish out the clumps, if not it will need to be dissembled to thoroughly clean it, if you use a air compressor use a toothpick to lock fan in place to prevent it from spinning faster then it's intended "burns up the bushings or bearings", and avoid going higher then 45 psi most compressors have a regulator you can turn down psi...
                          canned air works if the dust ain't too thick, if it is thick it will struggle. or simply dismantle and clean er out...
                          • thesloc
                            Banned
                            • Dec 2011
                            • 587
                            update; got it to work with windows 7 64-bit Home Premium. but there are no sound drivers available for it.
                            for some reason, it crashes and gets BSOD under a Win XP (64-bit) installation.
                            anyone have any solutions to this? should i try to download an OEM HP copy of Win xp media center that supposedly comes with it?
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Dv5000 Win64 sound driver:
                              http://64bitdrivers.com/driver.php?id=1375
                              • thesloc
                                Banned
                                • Dec 2011
                                • 587
                                ^doesn't work, i get an error "media device does not exist for this driver"
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  Extract the driver using 7-zip, then force install in Device Manager...
                                  (Update driver, don't I will choose which driver, ...)
                                  • thesloc
                                    Banned
                                    • Dec 2011
                                    • 587
                                    Thanks !
                                    Got it working now.
                                    • thesloc
                                      Banned
                                      • Dec 2011
                                      • 587
                                      Now I need a 64-bit video driver !
                                      If that doesn't work, I may have to downgrade the whole thing to 32-bit.
                                      • mockingbird
                                        • Dec 2008
                                        • 5484
                                        From http://www.w7forums.com/ati-radeon-x...-t2378p2.html:
                                        This is what to do and if you follow precisely, will be alright:
                                        1) Download this and run it so it extracts to C:\ATI
                                        ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35203.exe
                                        2) Close the installer immediately after extraction is done. Do not continue with install.
                                        3) Open device manager. Double click Display adapters section. Right click on standard vga and then choose update driver software. Then click the following:
                                        Browse my computer, let me pick, have disk. browse.
                                        Now navigate to within C:\ATI to where the .inf files are in the driver folder. Click or double click on the first one while shown in alphabetical order.
                                        Hit ok then hit next and it will install.
                                        5) Reboot and then choose an Aero theme and then also run the WEI score updater.
                                        Please let us know how this goes for ya and let us know if any complications.
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • trouble55
                                          NEC VersaPro PC-VRT42FBFR22B BIOS problem
                                          by trouble55
                                          Hi All,
                                          [Mother board model]
                                          V-VE212(U3E1)
                                          [Serial number]
                                          24000135PA
                                          [BIOS chip model]
                                          Macronix MX77L12850F
                                          I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                                          I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                                          I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                                          09-19-2024, 01:24 AM
