HP Elitebook 645 G10 BAD BIOS
  • hoaca388
    Badcaps
    • Jan 2022
    • 11809
    Originally posted by shiriff47
    Can anyone help me to unlock hp EliteBook 645 G10
    motherboard : DA0X9TMB8D1 REV D
    S/N : 5CD351K5LJ
    HP EliteBook 645 14 inch G10 Notebook PC
    CTNumber_6MBME0NWYIU0II
    Serial_5CD351K5LJ
    Sku_8J038EC#ABF
    Build Id_23WWKNBZ602#SABF#DABF
    Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPgSguhKjhk8mEmVn7nWpDpnpqprqMqz.tY
    • shiriff47
      • May 2018
      • 43
      • Algeria
      Serial_5CD351K5LJ
      Sku_8J038EC#ABF
      Thank you very much i found the solution.
      i will try to learn by comparing your unlocked dump with my locked one
      Thanks again
      • Allan Larson
        • Oct 2024
        Serial_5CD351K5LJ
        Sku_8J038EC#ABF
        What method did you use to unlock this? I'm using RCUnlocker and it says I need to use a 16MB chip but this 32MB W25Q256JV chip is the only one I see. Thanks!
        • madjid911
          • Dec 2016
          • 390
          • France
          Serial_5CD351K5LJ
          Sku_8J038EC#ABF
          Hello, thank you for sharing, I have the same laptop with password, I flashed this one, it worked no more password on the other hand it is blocked in manufacturing mode, can you tell me what is the DMI so that I can modify the bios with the original DMI please, or unlock my bios if it is simpler, because RCUNLOCK does not work with 32MB
          HP 645 G10 SERIAL 5CD347C1TD
          • minhdigital
            • Nov 2022
            • 757
            • Vietnam
            Send to you, try !!
            • madjid911
              • Dec 2016
              • 390
              • France
              #26
              Originally posted by minhdigital
              Send to you, try !!
              Hello, there is no more password but there is still the manufacturing block
              • madjid911
                • Dec 2016
                • 390
                • France
                #27
                Send to you, try !!
                I tried with the software with CMD and with your file writing file but I am still in manufacturing mode
                • minhdigital
                  • Nov 2022
                  • 757
                  • Vietnam
                  #28
                  Run write.bat in windows
                  • madjid911
                    • Dec 2016
                    • 390
                    • France
                    #29
                    Yes I tried but it doesn't work after restarting I still have the manufacturing
                    I tried to do it myself in CMD it tells me that it will be corrected but after restarting it remains the same
                    Click image for larger version  Name:	Capture.png Views:	59 Size:	32.3 KB ID:	3504935
                    • madjid911
                      • Dec 2016
                      • 390
                      • France
                      #30
                      Click image for larger version  Name:	Capture.png Views:	70 Size:	32.3 KB ID:	3504935
                      I would like to know why I always have the same problem, I tried several times, each time when restarting I always have the manufacturing message followed by a blank page indicating a product information not valid error. When I reopen the config file to redo it I realize that it is always on *unlock, so it is never saved
                      • keczuk
                        • Dec 2019
                        • 83
                        • WWW
                        #31
                        SerialNumber:5CD3284DW4
                        ProductConfigurationID:75C20AV
                        Board CT Number:PSBYR058JIB06N
                        Name:HP EliteBook
                        ProductName:HP EliteBook 645 14 inch G10 Notebook PC
                        BuildID:23WWKNBZ601#SABY#DABY
                        • volinakis
                          • Jan 2021
                          • 2738
                          • N/A
                          #32
                          rename config.tkt (???) or read again with BCU bios settings and name your file config.txt Open file with notepad and edit it with name, CT, etc - provided by minhdigital move * from Manufacturing Programming Mode to lock - as minhdigital​ indicate in Note.txt, save as config1.txt (save it in Documents and move it in BCU folder) and use BCU to write file : biosconfigutility[space]/set:config1.txt
                          • madjid911
                            • Dec 2016
                            • 390
                            • France
                            #33
                            Originally posted by volinakis
                            rename config.tkt (???) or read again with BCU bios settings and name your file config.txt Open file with notepad and edit it with name, CT, etc - provided by minhdigital move * from Manufacturing Programming Mode to lock - as minhdigital indicate in Note.txt, save as config1.txt (save it in Documents and move it in BCU folder) and use BCU to write file : biosconfigutility[space]/set:config1.txt
                            that's exactly what I did, but it starts without taking the modification, now it doesn't want to start normally, I must have done something stupid, it starts displays a hp sure smart recovery whitepaper error and turns off, I reflashed the original bios and it does exactly the same thing to me, it doesn't even boot on Windows anymore, it turns off after the error, can you clean the original bios please, I don't know what to do anymore
                            • volinakis
                              • Jan 2021
                              • 2738
                              • N/A
                              #34
                              that's exactly what I did, ....
                              sure, I can see from your printscreen ...
                              • minhdigital
                                • Nov 2022
                                • 757
                                • Vietnam
                                #35
                                Send to you, try again !!
                                • minhdigital
                                  • Nov 2022
                                  • 757
                                  • Vietnam
                                  #36
                                  Name:HP EliteBook
                                  Send to you, try !!
                                  • madjid911
                                    • Dec 2016
                                    • 390
                                    • France
                                    #37
                                    Send to you, try !!
                                    Thank you very much it works
                                    • BGinvestments
                                      • Jan 2024
                                      • 18
                                      • Colombia
                                      #38
                                      Hi! Can anyone help me to unlock a HP EliteBook 645 G10
                                      S/N 5CD4058S75
                                      This is the EC File
                                      • BGinvestments
                                        • Jan 2024
                                        • 18
                                        • Colombia
                                        #39
                                        S/N 5CD4058S75
                                        This is the EC File
                                        EDIT: i was wrong posting the EC File, this is the MAIN BIOS file
                                        • kuksi
                                          • Jan 2025
                                          • 3
                                          • Georgia
                                          #40
                                          Hello badcaps forum ! Please someone help me to remove bios password from HP 645 g10
                                          • peste
                                            peste commented
                                            Editing a comment
                                            post merged..
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
