Dell 7415 Bios Password
  • candela1
    • Sep 2024
    • 6
    This is the right one, sorry for that
    • candela1
      • Sep 2024
      • 6
      In the meantime, I tried to extract the .bin file from the official .exe with no success:
      - unzipped --> no apparent binary candidate among the files
      - Dell PFS Extract failed, so I assume it is not a PFS file
      - ./Inspiron_7415_2-in-1_1.24.0.exe /writeromfile fails with error "Invalid H2=FFT-W parameters (-writeromfile)
      - tried, out of curiosity to flash with NeoProgrammer the two files posted in this thread for the W25Q128FW (Mine is W25Q128JWSQ) .., and got an error:
      "Current programmer: CH341 Green
      22:56:01
      Old protection Register: 01010001(0x51),
      New protection Register: 01001100(0x4C),
      Programming memory(verifying)... Main Memory
      Verification error on address: 0x00000000, Device: 0xFA, Buffer: 0x82"
      On a side node, I'm using the CH341 green version set to 1.8V.
      So I will wait for your input.
      Thanks again for the support!
      • volinakis
        • Jan 2021
        • 2875
        • N/A
        22:56:01
        1. your bios backup has no volumes, means is corrupted.
        2. how did you set to 1,8V CH341? You have to use an adapter for 1,8V, search for "1.8V adapter for ch341a" and you'll understand
        3. Error is for bad or no contact of adapter with bios chipset terminals. Use ASProgrammer or Neo Programmer, not software came with CH341a
        4. platform for bios is Insyde so use insyde IFD extractor for bios update package
        5. you have attached bios image extracted from bios update, because your backup is corrupted i can't r ead DMI to transfer it.
        • candela1
          • Sep 2024
          • 6
          Hi volinakis, thanks a lot for your support.
          2. I have this version of CH341, which allows to set the voltage to 1.8, 2.5, 3.3 and 5 V: https://www.fruugo.de/ch341a-program...xoC4mEQAvD_BwE
          3. I use Neo Programmer
          I tried to flash the BIOS you provided, but got following error:
          1:01:02
          Old protection Register: 10000100(0x84),
          New protection Register: 00001010(0x0A),
          Verification error on address: 0x00000000, Device: 0x04, Buffer: 0x02
          Execution time: 00:00:00.038"
          I am going to try with the adapter as well and let you know.
          Edit: Second attempt worked well! Thank you!!!
          • Dangvantu
            member
            • Apr 2024
            • 43
            • Vietnam
            hi
            dell Inspiron 7415 2-in-1 laptop
            Service Tag: B639R93
            has bad bios,my bios is not showing up
            Someone please fix it
            thank you
            this is my bios​
            • shiyab
              • Sep 2023
              • 1646
              • india
              #26
              Originally posted by Dangvantu
              hi
              thank you
              this is my bios​
              hi try
              • Dangvantu
                member
                • Apr 2024
                • 43
                • Vietnam
                #27
                Originally posted by shiyab
                hi try
                Thank you, man
                • flo70
                  • Dec 2022
                  • 22
                  • france
                  #28
                  hello
                  Service Tag: GK09DL3
                  has bad bios
                  is it possible to fix please ?​
                    • 22084
                    Originally posted by flo70
                    hello
                    has bad bios
                    Please read the rules, you should not start a new thread with the same request. You are OK to bump your post after 48 hours if nobody has replied. https://www.badcaps.net/forum/troubl...before-posting
                    • flo70
                      • Dec 2022
                      • 22
                      • france
                      #30
                      ok i'm sory. I can't delete my message...
                      • LBTT1121
                        • Nov 2024
                        • 1176
                        • Việt Nam
                        #31
                        hello
                        has bad bios
                        hi, try
                        • flo70
                          • Dec 2022
                          • 22
                          • france
                          #32
                          Very good ! my laptop is ok now
                          Thank you !
                          • ALLOUTBOUND
                            • Apr 2025
                            • 4
                            • Belgium
                            #33
                            My Dell Inspirion 7415 was doing some firmware update stuff and now it is asking me "Enter Current Password:". I don't have set one.
                            Can anyone help? I saw that some people have ansered with a 8 number password. How do you calculate this from the service tag?
                            Anyhow, I would like to have a similar password, which fits to my service tag.
                            Thanks!
                            SERVICE TAG: CB3FFG3
                            And is it possible to read out the original UEFI Firmware chip when it is in the system? (using a Dediprog SF100)
                            Do I need to switch the system to G3 (completely off, battery removed)? Or does it work in S5 mode?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12396
                              #34
                              Thanks!
                              Post your dump.
                              • ALLOUTBOUND
                                • Apr 2025
                                • 4
                                • Belgium
                                #35
                                >Post your dump.
                                Here it is. Hopefully you can tell me the password.
                                Thanks!
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12396
                                  #36
                                  >Post your dump.
                                  Thanks!
                                  Try new file , non DMI.
                                  • ALLOUTBOUND
                                    • Apr 2025
                                    • 4
                                    • Belgium
                                    #37
                                    Thanks, this is the unchanged, "virgin" v1.27.0.
                                    But I was hoping someone can tell me the password of my system.
                                    When I use the new file, I guess that I will loose my Bitlocker key from TPM (let me assume that the Inspiron 7415 is using the AMD Firmware TPM, which stores its data into the SPI Flash ROM, and when a new, "virgin" UEFI FW is programmed, all the TPM data will be lost).
                                    So any chance to get just the password?
                                    Thanks!
                                    By the way:
                                    I can answer this now:
                                    It is possible to read out the original UEFI Firmware chip when it is in the system. I just disconnected the battery, so the system was in the G3 (fully off) state.
                                    • etronico2006
                                      • Jul 2015
                                      • 6
                                      • Ecuador
                                      #38
                                      Hello peste could you please help me with the DMI and windows key Block? For editing
                                      • lapfix
                                        • Mar 2020
                                        • 2765
                                        • my workshop
                                        #39
                                        Upload your bios
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Godfather79
                                          Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                          by Godfather79
                                          Hello everyone in the community
                                          Dear Sir,
                                          I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                          Problem details:
                                          * Model: Dell Latitude 5520.
                                          * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                          * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                          * Service Tag: (Enter your actual Service Tag from the laptop here)
                                          * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                          11-08-2025, 10:04 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
