yoga 730 13iwl bios bin
After programming the BIOS dump, the laptop behaved the same. By accident, I discovered that when I pressed the processor with my hand, the display would show an image. That’s how I confirmed there was a cold solder joint under the processor, and I gave up on the repair. I assume the main problem is that the processor is missing the X-shaped metal bracket that normally reinforces the board to prevent bending when tightening the screws, which likely caused the cold solder joint under the processor.Comment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by Loki_FidoHi everyone, hope everyone's having a great day.
I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
Does this mean the BIOS is fine? making it a hardware issue?
I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...-
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... - Loading...
