thinkbook 14,15 g4 iap bios bin NEED
  • lapfix
    • Mar 2020
    • 2575
    • my workshop
    #41
    Did ou try again the dump given by hoaca at post #36
    I think that you try without cmos connected !
    if yes , back the bios of hoaca , without charger without battery and without cmos press power button for 30 second
    try and give feedback​
    • igragon08
      • Sep 2022
      • 23
      • madrid
      #42
      Hi Lapfix, first of all, thank you very much for your help!
      I've performed both the BIOS reading and flashing without a charger connected, without the CMOS battery connected, without a battery, and
      even with and without RAM installed. I've tried multiple methods, and the same thing happened every time. I press the power button.
      The button lights up for a couple of seconds, then it turns off and won't boot. I've also tried the dump Hoaca provided me in post #36 again, as you mentioned. I even tried the dump you provided me again just in case.
      It might have flashed incorrectly for some reason, but nothing worked. I've checked all the connections on the board, but everything is fine, and I don't think it caused a short circuit because I've always taken precautions and grounded myself with a wrist strap to avoid static discharge. Honestly, I'm a little worried and frustrated. The only thing I haven't tried is the exact 30 seconds, but I have been holding the button for several seconds, but it hasn't worked. It always does the same thing: the button lights up, then turns off after a couple of seconds, and nothing. Honestly, it's very frustrating...​
      • igragon08
        • Sep 2022
        • 23
        • madrid
        #43
        Well, I waited the 30 seconds and nothing, the PC is dead, I'm starting to think that I have no solution, in addition, only the As programmer 2.1. 2 program is the only one that searching for the XMC25RH256C chip lets me do a dump and flash, I tried the Hoaca dump again and it didn't work, after doing the flashing, it decided to check the flash verification and it gave me a data verification error, but the flashing was done correctly, I'm starting to think that I don't know if the original reading I did is correct since I haven't been able to do any other readings, I don't flash with other versions of programs or with As programmer or with Neo programmer since they don't have this BIOS chip XMC25RH256C in the database and I'm not sure if the verification should not give any errors, I flashed again and the flashing was done correctly but the verification gave me a reading error, I tried with another programmer CH341a that I have it and the same thing; flashing is fine, but verification gives an error when reading, so I don't know what else to do. I hope you can give me a solution...
        • igragon08
          • Sep 2022
          • 23
          • madrid
          #44
          Well, I finally got it thanks to you all. I want to thank each and every one of you; Hoaca388, lapfix, danito, and especially SMDflea, who has been very patient with me. In general, thank you all for taking the time to answer my questions and helping me. The problem I was having was a flashing error. I tried several times, but it turned out it wasn't done correctly. Finally, with one of your clean images, it worked. Thanks again to all of you, and I hope to continue learning a little more with your help. A big hug, and see you soon!
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
          • vinaypundith
            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
            by vinaypundith
            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
            So, I'm looking for a BIOS dump for this machine - a 16MB one....
            08-03-2024, 12:32 PM
