DELL XPS 9315 bios dump needed
hello everybody, i need help my dell XPS 13 9315 turn on and after dell picture, no other image yet,it stays on.
motherboard number : hdp33 LA-L231P REV: 1.0(A00)Attached FilesComment
Type the laptop service tag, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...ore-postingComment
laptop model: dell xps 13 9315
service tag : 804ZVV3Comment
Hello try this file good luck ....Attached FilesComment
Hi everyone. Can you please help me. How do you guys program this chip? I tried witch ch341a but it doesn't support the w25r512j I even tried to manually choose similar chip and it reads but comes up with all ff.Comment
Please help me, my Dell XPS 13 9315 computer screen won't turn on, only the keyboard turns on and the capslock light flashes 2 times red and 7 times white
here my service tag and bios backup
ST : J3D1LR3
DELL XPS 13 9315Attached FilesComment
Before all attempt to your bios , try another LCD panel or its connection to the system board.Comment
Hi, I need to dump the XPS 13 9315 ST:97R5JR3 BIOS, after update stuck at Dell logo can't boot to windows. try to reinstall windows also can't boot.
Thank you.Attached FilesComment
I’m dealing with a firmware issue on a Dell XPS 9315. After PopOS build in firmware update tool found and install the BIOS v1.29.1, the laptop started showing TPM errors on boot:- Alert! TPM could not be initialized.
- Alert! TPM device is not detected.
Since then, the TPM is completely missing in BIOS and in the OS.
Here’s what I tried so far:- Downgrade is blocked because BIOS 1.29.1 is marked as “critical.”
- Reflashing the same version does not help.
- Left the laptop without battery for a week – no effect.
- Updated to BIOS 1.31.0 – problem persists.
- Dell support is useless – they only suggest paid motherboard replacement, even though the bug was clearly caused by their own BIOS update.
From the motherboard diagram, the TPM chip seems directly connected to the BIOS chip and loads its firmware from there. My suspicion is that the TPM firmware region in the BIOS got corrupted during the update.
I dumped my current BIOS and also tried patching it with 8FC8, but no luck. I’m attaching my BIOS dump here in case someone with more experience can take a look and maybe correct the corrupted region.
Laptop service tag is: 5360B24
Any help would be greatly appreciated.
Thanks!Attached FilesComment
XPS 13 9315Hi everyone,
Thanks!
Service Tag: 5360B24Attached Files↵
https://www.badcaps.net/donateComment
Thanks for your work, unfortunatelly the downgrade to bios version 1.26.0 did not fix the issue. Now i run windows and on the first reboot the Windows installed bios v1.29.1 also with no difference. I notice something strange with the bios setup GUI for v1.31.0 in windows, Backup Embedded Controller has the current version 1.8.1 and the installer version is 1.0.9. Maybe the linux firmware utility installed a bios that was made for this platform but not exactly this motherboard?
Thanks!
tryThanks for your work, unfortunatelly the downgrade to bios version 1.26.0 did not fix the issue. Now i run windows and on the first reboot the Windows installed bios v1.29.1 also with no difference. I notice something strange with the bios setup GUI for v1.31.0 in windows, Backup Embedded Controller has the current version 1.8.1 and the installer version is 1.0.9. Maybe the linux firmware utility installed a bios that was made for this platform but not exactly this motherboard?
XPS 13 9315
Service Tag: 11XT2T3
bios error please help thank youAttached FilesComment
Hello try this file perhaps it helps ....Attached FilesComment
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by jamaica12345i need dump bios dell vostro 3710 please help
Service Tag 2FL5NY3
CI bios
MX25L25635
MX25L12805...-
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
Channel: BIOS Requests ONLY!
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
- Loading...
