need BIOS for ASUS Zephyrus GA503RM
Need working bios file
Model - asus zephyrus ga503rm
serial - n4nrcx02v684155
mobo serial - danjpmb2aa00rev
Issue - device will power on, keys light fans spins but black screen and no boot. I flashed all 3 files from this thread and all had same outcome. No change in behavior. Please help.
attached bios dumpAttached Files1 PhotoComment
Hi there, can someone help me to fix this bios, i tried with de dump on post ·6 and it shows video but keyboard and backlight keyboard are not working with this bios, with the original dump most of the times it does not show display, but sometimes it works and the keyboard and the backlight works ok, so i think the dump of post 6 is a diferent model of motherboard, the motherboard model is danjpmb2aa0 rev A the laptop model is ga503rm-g15.r93060 sn : N8NRCX08R24834E
Attached FilesComment
Hi there, can someone help me to fix this bios, i tried with de dump on post ·6 and it shows video but keyboard and backlight keyboard are not working with this bios, with the original dump most of the times it does not show display, but sometimes it works and the keyboard and the backlight works ok, so i think the dump of post 6 is a diferent model of motherboard, the motherboard model is danjpmb2aa0 rev A the laptop model is ga503rm-g15.r93060 sn : N8NRCX08R24834EDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
thanks for answer peste, i tried with your dump but it has de same problem, shows display but keyboard and backlight keyboard does not work, i tried again with my original dump and it does not work either , im thinking that the kbc it8252e248a it is corrupted, can you tell me where to find the dump of the kbc and how to program it with a rt809f programmer, or do i need to replace that it8252e248a?Comment
https://www.badcaps.net/forum/showthread.php?t=69782
https://www.badcaps.net/forum/showpo...57&postcount=4
Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Full name: ROG Zephyrus G15 GA503RM
Motherboard: DAONJPMBADO REV: D
Original BIOS with onboard RAM enabled in attachment.Attached FilesComment
Please, i need bios bin file for my GA503RM, thank you so much
GA503RM-G15.R93060
SN: N6NRCX09661825F
DANJPMB2AB1REV : B oldBios.rarComment
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by skipron.rmHello everyone, trust you're doing well.
I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...-
by skurvysynHello,
laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...-
Hello everyone I stupidly updated the bios on my Asus and it got corrupted.
Can anyone edit the hex bios file for my device? My bios chip W25Q16JVSNIQ Winbond has a capacity of 16Mb but the bios file I downloaded on the Asus homepage is 32Mb. Can anyone help me edit the hex and adjust it for me so I can flash the bios, please?
Thank you so much😥
This is the original bios file from Asus website and motherboard number:
model number: GA402XI-PMV-VGT
6050A3447304-MB-A01...-
- Loading...
