need BIOS for ASUS Zephyrus GA503RM
Need working bios file
Model - asus zephyrus ga503rm
serial - n4nrcx02v684155
mobo serial - danjpmb2aa00rev
Issue - device will power on, keys light fans spins but black screen and no boot. I flashed all 3 files from this thread and all had same outcome. No change in behavior. Please help.
attached bios dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
1 PhotoComment
Hi there, can someone help me to fix this bios, i tried with de dump on post ·6 and it shows video but keyboard and backlight keyboard are not working with this bios, with the original dump most of the times it does not show display, but sometimes it works and the keyboard and the backlight works ok, so i think the dump of post 6 is a diferent model of motherboard, the motherboard model is danjpmb2aa0 rev A the laptop model is ga503rm-g15.r93060 sn : N8NRCX08R24834E
Bios extracted from Asus website update for ROG Zephyrus G15 (2022) GA503Hi there, can someone help me to fix this bios, i tried with de dump on post ·6 and it shows video but keyboard and backlight keyboard are not working with this bios, with the original dump most of the times it does not show display, but sometimes it works and the keyboard and the backlight works ok, so i think the dump of post 6 is a diferent model of motherboard, the motherboard model is danjpmb2aa0 rev A the laptop model is ga503rm-g15.r93060 sn : N8NRCX08R24834EAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
thanks for answer peste, i tried with your dump but it has de same problem, shows display but keyboard and backlight keyboard does not work, i tried again with my original dump and it does not work either , im thinking that the kbc it8252e248a it is corrupted, can you tell me where to find the dump of the kbc and how to program it with a rt809f programmer, or do i need to replace that it8252e248a?Comment
you don't have problems with the KBC... maybe this will help you...thanks for answer peste, i tried with your dump but it has de same problem, shows display but keyboard and backlight keyboard does not work, i tried again with my original dump and it does not work either , im thinking that the kbc it8252e248a it is corrupted, can you tell me where to find the dump of the kbc and how to program it with a rt809f programmer, or do i need to replace that it8252e248a?
https://www.badcaps.net/forum/showthread.php?t=69782
https://www.badcaps.net/forum/showpo...57&postcount=4
https://www.badcaps.net/donateComment
S/N: N1NTCX00158403H
Full name: ROG Zephyrus G15 GA503RM
Motherboard: DAONJPMBADO REV: D
Original BIOS with onboard RAM enabled in attachment.Attached Filesif you find these attachements useful please consider making a small donation to the site
Please, i need bios bin file for my GA503RM, thank you so much
GA503RM-G15.R93060
SN: N6NRCX09661825F
DANJPMB2AB1REV : BAttached Filesif you find these attachements useful please consider making a small donation to the site
ROG Zephyrus G15 (2022)_GA503RMAttached Filesif you find these attachements useful please consider making a small donation to the site
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by skipron.rmHello everyone, trust you're doing well.
I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
