HP Elitebook 850 G8 Bios unlock
  • breitkrug
    • Aug 2022
    • DE
    Hi, I have 3 HP 850 G8 here.
    I was able to remove the password (mostly by try and error) but it still has the endpoint security problem.
    Is there a “manual” or an HowToo what needs to be changed / what I need to look out for in the bin files? For the password removal and the endpoint security thing.
    I hope someone can help me 😊
    I've attached both dumps from laptop one.
  • Paul.Junge2020
    • Feb 2023
    • 36
    • Ukraine
    Hello. i need unlock bios for HP 850 g8.
    5CG2147D8T
    • rex98
      • Feb 2023
      • 1287
      • Mandaue CEBU, Philippines
      5CG2147D8T
      flash that in first boot reset security to defaults.
      • Elaid02
        • May 2022
        • 34
        • FRANCE
        hi
        unlock bios code for this hp 850 G8
        dump are attached
      • Elaid02
        • May 2022
        • 34
        • FRANCE
        Originally posted by Elaid02
        hi
        dump are attached
        5CC145CMP1
        • rex98
          • Feb 2023
          • 1287
          hi
          dump are attached
          flash only the dump 2 do not touch the main.
          • beast4ever
            • Feb 2015
            • 174
            • egypt
            Hi friends
            I want to delete the password
            hp elitebook 850 g8
            • Vesko356
              Vesko356 commented
              Editing a comment
              You MUST:
              Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
              Name your thread with make, full model numbers and request
          • hoaca388
            Badcaps
            • Jan 2022
            • 12171
            Originally posted by beast4ever
            Hi friends
            hp elitebook 850 g8
            prdid : 1g1x8av
            sn: 5cg2471ttr
            Unlocked
            • beast4ever
              • Feb 2015
              • 174
              • egypt
              Originally posted by hoaca388
              Unlocked
              Thank you, great job
              • volcour
                • Dec 2015
                • 92
                • algiria
                hello everyone
                HP Elitebook 850 G8 It gives this message after unlocking the password
                -​HP endpoint security controller problem
                SN :5CG1324ST9
                • Vesko356
                  Vesko356 commented
                  Editing a comment
                  Upload second (main) bios dump.
              • volcour
                • Dec 2015
                • 92
                • algiria
                Sorry for the delay, I cannot download directly to the site
                http://*******/file/9hf1l3*******/U367_main.rar
              • qayyum786
                • Aug 2018
                • 1958
                • INDIA
                Attach same as you posted @ post #10
                compress file in winzip or winrar and use Upload Attachments tab
                • volcour
                  • Dec 2015
                  • 92
                  • algiria
                  I have had a problem since yesterday, I have not been able to upload the file to the site
                  Click image for larger version  Name:	Capture.png Views:	0 Size:	106.2 KB ID:	3210674
                    SMDFlea commented
                    Editing a comment
                    Rename the file with no underscore, and try postin in a zip file instead
                • volcour
                  • Dec 2015
                  • 92
                  • algiria
                  main bios U367
                  • qayyum786
                    • Aug 2018
                    • 1958
                    • INDIA
                    At 1st boot press F10 and RESET BIOS to factory defaults
                    • LJP42
                      Hi friends,
                      i wanna unlock the bios for Hp elitebook 850 gb
                      SN: 5CG13012JZ
                      ProdID: 1G1X7AV
                      • Vesko356
                        Vesko356 commented
                        Editing a comment
                        Upload your bios backup.
                    • Quin TeknoLife
                      • Mar 2024
                      • 21
                      • the Netherlands
                      Could someone remove bios pw? i wasn´t sure which one to remove and dump so I dumped the chip on the backside of the motherboard
                      Elitebook 850 g8
                      prodid 358R8EA#ABH
                      s/n 5CG1377DTM
                      I cannot attach the archive, it errors every time so I uploaded it to my own server.
                      http://******.nl/dump.rar
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12171
                        Originally posted by Quin TeknoLife
                        Could someone remove bios pw? i wasn´t sure which one to remove and dump so I dumped the chip on the backside of the motherboard.
                        Elitebook 850 g8
                        prodid 358R8EA#ABH
                        s/n 5CG1377DTM
                        Use winrar or 7zip to compress your bios file before uploading it here.
                        • Quin TeknoLife
                          • Mar 2024
                          • 21
                          • the Netherlands
                          it already is in an archive called dump.rar, didn´t change nothing
                          edit: tried a zip instead of a rar and that worked
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12171
                            Elitebook 850 g8
                            prodid 358R8EA#ABH
                            s/n 5CG1377DTM
                            Unlocked
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • Wutru
                              HP Elitebook 820 G4 BIOS repair assistance required
                              by Wutru
                              Hi guys,
                              If someone would be able to provide some expertise, I'd be very grateful.
                              BIOS Corruption - Cause
                              So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                              After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                              09-06-2025, 10:32 AM
                            • STKR123
                              The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                              by STKR123
                              Greetings badcaps community,
                              I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                              So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                              Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                              I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                              These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                              I learned that desoldering...
                              10-29-2024, 06:03 AM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • clrscr
                              Need unlock bios hp elitebook 835 G11
                              by clrscr
                              please help me unlock bios password hp elitebook 835 G11
                              S/N: 5CG50434RD
                              thanks!...
                              06-04-2025, 09:38 PM
