HP Elitebook 850 G8 Bios unlock
I need a clean BIOS for HP Elitebook 850-G8
SN : 5CD114FPWC . The attached one is corrupt, boot is stuck on Hp Sure Start Recovery Loop
Thank on advanceAttached FilesPremium supporters get full download access and other benefits.
EmeriComment
Last edited by SMDFlea; 09-12-2025, 11:36 AM. Reason: edited. No need to post the same bios again...EmeriComment
I'm lost since RCUnlock doesn't seem to support 32mb dumps. I'm trying to remove the BIOS password.
I have attached the dumps from both the front (BIOS?) chip and back (EC?) chip, both 32mb.
I'm confused as to which one does what, and which to flash.
Some items show up in yellow or red in UEFITool. Unsure if that's important or means anything.
Here is laptop info:
HP Elitebook 850 G8
Serial Number
5CG2136LGT
Product ID
1G1X8AV
SKU Number
1G1X8AV
Feature Byte
476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfPgSguhKjhk8mEmVmwn7nVngpDpq.Aq
I have access to the BCU GetConfig file if that's any use.
Any help appreciated!Attached FilesPremium supporters get full download access and other benefits.
Any luck?Hi,
HP Elitebook 850 G8
Serial Number
5CG2136LGT
Product ID
1G1X8AV
SKU Number
1G1X8AV
Feature Byte
Any help appreciated!Comment
Yes.Attached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
HP EliteBook x360 830 G8
ProID 17N22AV
SN 5CG3275LNS
Feature Byte:
476J6S6b7B7H7M7R7W7maBaEapaqauawbVcAd 6eMfPfXgSguhKjhk8mEmVn7nVngpDpnpqpr.YA
Build ID: 21WWOPEZ601#SUUN#DUUN
It has an MDM lock. If anyone can help, many thanksAttached FilesPremium supporters get full download access and other benefits.
TryAttached FilesPremium supporters get full download access and other benefits.
I previously took a BIOS chip from another laptop of the same model and tested it there, and most likely the EC is also faulty.
This laptop has a company lock. After connecting to the internet, I have to enter the company email or the security password.
Thanks a lot
I have flashed your file onto the rear chip, and left the front BIOS chip as is.
The screen stays black on boot, and the capslock and NumLock flash white 7 times.
The laptop doesn't boot. I have tried AC only, etc..
Do I need to flash the front BIOS chip too?
Kind regardsComment
Try it
After Flash Patched File, in First BOOT got to setup restore Factory defaults and save and exit flash back Original BiosAttached FilesPremium supporters get full download access and other benefits.
Kind regards
Possible to take another look at it please?
Thank you!Comment
Elitebook 850 G8
SN = 5CG1300T63
6050A3216701 MB A01 (A1)
Remove bios password(IGNORE THE BACKUP NAMING, should be 850 G8)Attached FilesPremium supporters get full download access and other benefits.
Hello everyone,- I read the original BIOS dump using a programmer and immediately flashed it back to ensure the read was correct.
- Since the first programming cycle (read and write-back), the system no longer boots and LED errors, which suggests a corrupt or initialized ME region that was only triggered by the programming cycle itself.
- I attempted to clean the ME region myself by copying the ME region from another original dump. This attempt likely resulted in a hard brick, and the laptop no longer starts at all (no lights, no fan spin).
- Currently, the original dump (Main.bin) is back on the chip, but the system still does not boot; the LEDs briefly light up, turn off, and then light up again (indicating a non-passing POST).
My Data:- Laptop Model: HP EliteBook 850 G8
- Original ME Version: 15.0.50.2633
- Flash Image Tool: 15.0.23.1706
- SN: 5CG1311C6Z
Could someone please explain the cause and clear the ME of this BIOS file?Attached FilesPremium supporters get full download access and other benefits.
Hello guys,
Can you help unlock my HP Elitebook 850 G8 please?
I tried to remove ActiveReign in EC chip, that removed the password but I have an issue with Endpoint Security at boot. I don't have the solution.
Board : 6050A3216701-A01(A1)
ProdID : 2Y2R8EA#ÃBF
SN : 5CG221BXC1
Feature Byte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPguhKhkjhk8mEmwn7nVng yg
Build ID : 21WWCVET601#SABF#DABF
INFO : the original.zip file is EC ROM.
Thank you guys <3Attached FilesPremium supporters get full download access and other benefits.
Thank you!
try the endpoint script patcher - https://www.badcaps.net/forum/troubl...security-error
I tried again and only removed ActiveReign in EC ROM. On the first boot I still had the Endpoint error, but I was able to access the BIOS setup, so I performed a security reset, and on the second boot I did a factory reset.
No more errors — it’s working now!
Thank you for your help
Channel: BIOS Requests ONLY!
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by macabookHello everyone,
07-24-2025, 02:17 PM -
by adobe szkHello everyone, I need help unlocking the BIOS on my HP EliteBook 840 G8 laptop. I have tried many methods, but nothing worked. I am attaching the original dumps of the Main and EC....
- Loading...
