HP Elitebook 850 G8 Bios unlock
  • breitkrug
    • Aug 2022
    • DE
    Hi, I have 3 HP 850 G8 here.
    I was able to remove the password (mostly by try and error) but it still has the endpoint security problem.
    Is there a “manual” or an HowToo what needs to be changed / what I need to look out for in the bin files? For the password removal and the endpoint security thing.
    I hope someone can help me 😊
    I've attached both dumps from laptop one.
  • Paul.Junge2020
    • Feb 2023
    • 36
    • Ukraine
    Hello. i need unlock bios for HP 850 g8.
    5CG2147D8T
    • rex98
      • Feb 2023
      • 1280
      • Mandaue CEBU, Philippines
      5CG2147D8T
      flash that in first boot reset security to defaults.
      • Elaid02
        • May 2022
        • 34
        • FRANCE
        hi
        unlock bios code for this hp 850 G8
        dump are attached
      • Elaid02
        • May 2022
        • 34
        • FRANCE
        Originally posted by Elaid02
        hi
        dump are attached
        5CC145CMP1
        • rex98
          • Feb 2023
          • 1280
          hi
          dump are attached
          flash only the dump 2 do not touch the main.
          • beast4ever
            • Feb 2015
            • 162
            • egypt
            Hi friends
            I want to delete the password
            hp elitebook 850 g8
            • Vesko356
              Vesko356 commented
              Editing a comment
              You MUST:
              Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
              Name your thread with make, full model numbers and request
          • hoaca388
            Badcaps
            • Jan 2022
            • 11813
            Originally posted by beast4ever
            Hi friends
            hp elitebook 850 g8
            prdid : 1g1x8av
            sn: 5cg2471ttr
            Unlocked
            • beast4ever
              • Feb 2015
              • 162
              • egypt
              Originally posted by hoaca388
              Unlocked
              Thank you, great job
              • volcour
                • Dec 2015
                • 90
                • algiria
                hello everyone
                HP Elitebook 850 G8 It gives this message after unlocking the password
                -​HP endpoint security controller problem
                SN :5CG1324ST9
                • Vesko356
                  Vesko356 commented
                  Editing a comment
                  Upload second (main) bios dump.
              • volcour
                • Dec 2015
                • 90
                • algiria
                Sorry for the delay, I cannot download directly to the site
                http://*******/file/9hf1l3*******/U367_main.rar
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                Attach same as you posted @ post #10
                compress file in winzip or winrar and use Upload Attachments tab
                • volcour
                  • Dec 2015
                  • 90
                  • algiria
                  I have had a problem since yesterday, I have not been able to upload the file to the site
                  Click image for larger version  Name:	Capture.png Views:	0 Size:	106.2 KB ID:	3210674
                    SMDFlea commented
                    Editing a comment
                    Rename the file with no underscore, and try postin in a zip file instead
                • volcour
                  • Dec 2015
                  • 90
                  • algiria
                  main bios U367
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    At 1st boot press F10 and RESET BIOS to factory defaults
                    • LJP42
                      Hi friends,
                      i wanna unlock the bios for Hp elitebook 850 gb
                      SN: 5CG13012JZ
                      ProdID: 1G1X7AV
                      • Vesko356
                        Vesko356 commented
                        Editing a comment
                        Upload your bios backup.
                    • Quin TeknoLife
                      • Mar 2024
                      • 21
                      • the Netherlands
                      Could someone remove bios pw? i wasn´t sure which one to remove and dump so I dumped the chip on the backside of the motherboard
                      Elitebook 850 g8
                      prodid 358R8EA#ABH
                      s/n 5CG1377DTM
                      I cannot attach the archive, it errors every time so I uploaded it to my own server.
                      http://******.nl/dump.rar
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11813
                        Originally posted by Quin TeknoLife
                        Could someone remove bios pw? i wasn´t sure which one to remove and dump so I dumped the chip on the backside of the motherboard.
                        Elitebook 850 g8
                        prodid 358R8EA#ABH
                        s/n 5CG1377DTM
                        Use winrar or 7zip to compress your bios file before uploading it here.
                        • Quin TeknoLife
                          • Mar 2024
                          • 21
                          • the Netherlands
                          it already is in an archive called dump.rar, didn´t change nothing
                          edit: tried a zip instead of a rar and that worked
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11813
                            Elitebook 850 g8
                            prodid 358R8EA#ABH
                            s/n 5CG1377DTM
                            Unlocked
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • STKR123
                              The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                              by STKR123
                              Greetings badcaps community,
                              I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                              So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                              Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                              I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                              These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                              I learned that desoldering...
                              10-29-2024, 06:03 AM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • clrscr
                              Need unlock bios hp elitebook 835 G11
                              by clrscr
                              please help me unlock bios password hp elitebook 835 G11
                              S/N: 5CG50434RD
                              thanks!...
                              06-04-2025, 09:38 PM
                            • Guest
                              Elitebook 850 G5 BIOS bricked
                              by Guest
                              I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                              I assume the BIOS update failed, so I searched for the BIOS chip.
                              I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                              However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                              Can the corrupted...
                              03-24-2025, 01:21 AM
