Hp elitebook 840 g9
  • sdkwq
    • Mar 2025
    • 5
    • austria
    #281
    plz remove the password.
    the flash file is from the ic near the ram modules, SPI
    HP 840 G9
    SN: #5CG24604WJ
    • minhdigital
      • Nov 2022
      • 758
      • Vietnam
      #282
      HP 840 G9
      SN: #5CG24604WJ
      Send to you
      • lapfix
        • Mar 2020
        • 2742
        • my workshop
        #283
        HP 840 G9
        SN: #5CG24604WJ
        YOU MUST follow these steps :
        1) First boot will delay a few minutes
        2) IMPORTANT: Go to BIOS Setup ( F10 ) and reset to Factory Default (first main page tab)
        3) Restart and enter BIOS
        4) 2nd boot restore security settings to defaults.
        ​Try and Give Fedback
        • dhan
          • Jun 2018
          • 134
          • hp
          #284
          EliteBook 840 G9
          SERIAL: 5CG33038Z7
          please help.
          No POST.
          keyboard backligh is on, Fan Spins, but no display.
          SPI and EC attached.​
          • smallvhin
            • Jul 2015
            • 183
            • philippines
            #285
            help master to unlock password more thanks
            SN:5CG331191J
            • smallvhin
              • Jul 2015
              • 183
              • philippines
              #286
              I'm trying to edit mpm and copy the offset of other working bios but no lock. recovering bios password show up.
              SN:5CG331191J
              • sdkwq
                • Mar 2025
                • 5
                • austria
                #287
                Originally posted by EdMac
                I spent the last few days trying to unlock it! However, when I tried to remove the EC bios, I messed everything up! Some resistors moved out of place and I'm not sure about their position and their values.
                Could a friend of mine send me a photo of this area (photo below) and, if possible, the value of the resistors in red.
                Thank you in advance for your help!!
Name:	Ec bios area.jpg
                Where those resistors?
                top / bottom i can check
                • sdkwq
                  • Mar 2025
                  • 5
                  • austria
                  #288
                  here's the situation:
                  • Flashed the file
                  • Got an EC error
                  • Desoldered the chip again
                  • Tried to flash externally
                  • W25Q256JV was damaged
                  • Bought a new chip
                  • Flashed the unlocked file from here onto the new chip
                  • Still got an EC error
                  • Checked and resoldered all points
                  Now the Caps Lock LED blinks white seven times.
                  Is the hp now broken?
                  • smallvhin
                    • Jul 2015
                    • 183
                    • philippines
                    #289
                    SN:5CG331191J
                    It's working self study more thanks master to support 😊👍
                    • jonico2007
                      • May 2022
                      • 28
                      • Philippines
                      #290
                      Can you please unlock my bios
                      Serial: 5CG33119K7
                      Built ID: 22WWWPBZ602#SUUF#DUUF
                      Board CT: PQSPQ00WBIE09C
                      Name: HP EliteBook 840 G9
                      Asset Tag#: 0819877​
                      • jonico2007
                        • May 2022
                        • 28
                        • Philippines
                        #291
                        Ec file
                        • jonico2007
                          • May 2022
                          • 28
                          • Philippines
                          #292
                          Please remove the bios password
                          Serial: 5CG33119K7
                          Name: HP EliteBook 840 G9​
                          • tuyen821991
                            • Oct 2024
                            • 44
                            • Viet Nam
                            #293
                            Serial: 5CG33119K7
                            TRY
                            • jonico2007
                              • May 2022
                              • 28
                              • Philippines
                              #294
                              Originally posted by tuyen821991
                              TRY
                              Will try thanks
                              • rex98
                                • Feb 2023
                                • 1281
                                • Mandaue CEBU, Philippines
                                #295
                                I noticed there's a lot of unlock request for this model HP EliteBook 840 14 inch G9
                                The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
                                first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                use BCU and put your original DMI.
                                frequently asked questions:
                                can i use this to my HP EliteBook 680 14 inch G9- yes
                                This is the both BID U70 and U71 its the most common BID. i don't have U76, but let me know if you want U76.
                                This bios main is from official website then added VSSTORE and patched so its fast-boot & Clearme.
                                To determine your BID use hex editor and search U70 or U71 in your main bios bin or EC, you know the rest.​
                                • diver111
                                  • Nov 2020
                                  • 5
                                  • Ukraine
                                  #296
                                  Please help i need to remove password from HP 840 G9.
                                  THANK YOU !
                                  sn : 5CG34351QY
                                  SKU: 9B2L2EC#ABD
                                  BIOS: U71 Ver.01.09.00
                                  • lapfix
                                    • Mar 2020
                                    • 2742
                                    • my workshop
                                    #297
                                    THANK YOU !
                                    sn : 5CG34351QY
                                    SKU: 9B2L2EC#ABD
                                    Applied factory defaults on first boot (F10)
                                    Skipped the "Reset Security Settings" step on second boot .
                                    Used BCU to restore original DMI
                                    Try and Give feedback
                                    • diver111
                                      • Nov 2020
                                      • 5
                                      • Ukraine
                                      #298
                                      Everything works. Thanks. I didn't succeed with BCU, I flashed the backup copy, but the password didn't return.
                                      • lapfix
                                        • Mar 2020
                                        • 2742
                                        • my workshop
                                        #299
                                        Good...so after you try my unlocked bios..no pwd..but you desoldered and try again your original bios and all is ok !
                                        • diver111
                                          • Nov 2020
                                          • 5
                                          • Ukraine
                                          #300
                                          Everything is correct. I flashed your patched bios. when trying to transfer dmi with the BCU program, errors occurred. I unsoldered the chip again and flashed the old bios file. what is interesting is that during the manipulations with the files, the laptop updated the bios to the latest version, and the old file remained at version 01.09.00. after re-flashing the bios updated again. resets of the main bios and security system were required. and many long reboots. in the end, everything works and there is no password!
