Hp elitebook 840 g9
  • maximilianus
    • May 2024
    • 9
    • Austria
    #101
    #97 Is the BIOS that is not needed need the other one from the front of the motherboard ?
    • maximilianus
      • May 2024
      • 9
      • Austria
      #102
      Please remove BIOS Administrator Password
      hp Elitebook 840 G9
      Build ID : 22WWWPBZ602#SABU#DABU
      sn/ 5CG3124DQ4​
      • Dan20701
        • Sep 2020
        • 204
        #103
        hp Elitebook 840 G9
        sn/ 5CG3124DQ4​
        I am not 100% sure you got a good reading try saving a few more backups before reprogramming, Give the file a go I done my best.
        • maximilianus
          • May 2024
          • 9
          • Austria
          #104
          I read it 10 times with asprogrammer and neoprogrammer and it's always the same checksum
          I Writte this hp840g9front No Password.bin and the keyboard lit up and blocked everything, only three LEDs above the function keys turned on.
          the laptop is stuck there
          I will see on Monday to return the original bin
          • rex98
            • Feb 2023
            • 1293
            • Mandaue CEBU, Philippines
            #105
            hp Elitebook 840 G9
            sn/ 5CG3124DQ4
            first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
            use BCU. you can permanently disable Absolute lock in BCU.
            here's your DMI:
            Serial Number: 5CG3124DQ4
            Product #/SKU: 6T1H6EA#ABU
            CT Number: PPQBH00WBHU1H1
            Description: HP EliteBook 840 14 inch G9
            BuildID: 22WWWPBZ602#SABU#DABU
            Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfAfPguhKhkjhk8mEn7nVngpTpWpnpqprqjqz.GM​
            • maximilianus
              • May 2024
              • 9
              • Austria
              #106
              first boot press f10 apply factory defaults and restart, ..... this works, MPM ... I can also browse the BIOS menu, I couldn't before
              2nd boot reset security ...... it won't, it will always ask me for the ADMIN password
              • maximilianus
                • May 2024
                • 9
                • Austria
                #107
                I've been trying for hours f10 and factory reset works normally ... The MPM timer always resets after that. I entered all the DMI values from the bios ....
                Just reset security ...... it won't, it will always ask me for the ADMIN password..
                Can someone calculate the Admin password from the bin file?​
                • souaqi01
                  • Dec 2015
                  • 87
                  • Maroc
                  #108
                  hi any one help plz for unlock the bios hp elitebook 840 g9
                  SN 5CG3252VHK
                  • Dan20701
                    • Sep 2020
                    • 204
                    #109
                    SN 5CG3252VHK
                    Give this a try
                    • rex98
                      • Feb 2023
                      • 1293
                      #110
                      SN 5CG3252VHK
                      here's your DMI:
                      Serial Number: 5CG3252VHK
                      Product #/SKU: 88S79EC#ABE
                      CT Number: PPQBC00WBI726K
                      BuildID: 22WWWPBZ602#SABE#DABE
                      Feature Byte: 476J6S6b7B7H7M7Q7W7m7saEapaqauawbUbhcAfPgSguhKjhk8mEn7nVngpDpFpVpnpqprqjqz.HB
                      MAC Address : BC:0F:F3:47:2B:C8​
                      • souaqi01
                        • Dec 2015
                        • 87
                        • Maroc
                        #111
                        here's your DMI:
                        thank you very much it working
                        • souaqi01
                          • Dec 2015
                          • 87
                          • Maroc
                          #112
                          Originally posted by Dan20701
                          Give this a try
                          thanks
                          • dihcar84
                            • Aug 2012
                            • 201
                            • morocco
                            #113
                            unlock please
                            840 G9 SN:5CG2461L2C
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12330
                              #114
                              Originally posted by dihcar84
                              unlock please
                              HP EliteBook 840 14 inch G9 Notebook PC
                              CT Number_6MBNF0CWYH78KQ
                              Serial_5CG2461L2C
                              Sku_5Z695EA#ABH
                              Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPguhKhkjhk8mEmGn7nVngpTpppqqjqz.dD
                              Build Id_22WWWPAT602#SABH#DABH
                              • dihcar84
                                • Aug 2012
                                • 201
                                • morocco
                                #115
                                Serial_5CG2461L2C
                                Sku_5Z695EA#ABH
                                thank you
                                • munir100
                                  • Dec 2018
                                  • 188
                                  • uae
                                  #116
                                  i have a HP elitebook 840 g9 bios password pls can any one removd password here is bios file s/n 5CG2362VDT
                                  • dihcar84
                                    • Aug 2012
                                    • 201
                                    • morocco
                                    #117
                                    Serial_5CG2461L2C
                                    Sku_5Z695EA#ABH
                                    after writing all this bios locked
                                    • rex98
                                      • Feb 2023
                                      • 1293
                                      #118
                                      after following my instruction to get rid of Manufacturing mode. use BCU.
                                      here's your DMI:
                                      Serial Number: 5CG2362VDT
                                      Product #/SKU: 6Z4A9UP#ABA
                                      CT Number: PQSPN00WBH319X
                                      BuildID: 22WWWPAT602#SABA#DABA
                                      Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPgSguhKjhk8mEmwn7nVngpDpVpqqjqz.Eg
                                      MAC Address : 38:CA:84:4E:59:F7​
                                      • munir100
                                        • Dec 2018
                                        • 188
                                        • uae
                                        #119
                                        here's your DMI:
                                        Thank s password is removed
                                        • maobuff
                                          • Jul 2024
                                          • 5
                                          • Ukraine
                                          #120
                                          Can someone unlock bios for HP elitebook 840 g9?
                                          SN# 5CG23634TL
