Hp elitebook 840 g9
HI Please Help me removing this admin pass
HP Elitebook 840 G9 14inch
SN # BRJ345B9ZPAttached FilesComment
hi,please help unlock
840 G9
SN:5CG40114QYAttached FilesComment
HI every one i have hp 840 g9 with bios password can any remove password hara is bios file SN-5CG3040LP3Attached FilesComment
hi vtry this file flash and feedbackComment
i have hp elitebook 840 g9 bios password i try to removed password but not secufull hare is bios file can any one pls clear password sn-5CG3040LP3Attached FilesComment
How about friends, I have this bios from an HP elitebook 840 g9, the problem is that it doesn't give me an image, it just spins the fan quickly, thank you in advance.
SN:5CG2351ZR6
PRUDUCT ID: 6D763LT
HP ELITEBOOK 840 G9Attached FilesComment
hp elitebook 840 g9 with bios adminstrator C HARAredential i Try to fix but not sceufull hara is bios can any one fix for me thanks in advced SN -5CG3040LP3 Hear is both fileAttached FilesComment
Can someone Remove the Bios Password of the HP Elitebook 840 G9 (Intel VPro i5) and the Laptop is also MDM Locked!
Processor: 12th Gen
Serial Number: 5CG33501TQ
SKU Number: 6Z7M1EC#ABA
I have attached both the original and modified bios file, I tried to remove the password but no luck it is still bios locked.
NOTE: I tried modifying the NVRAM region to FF in the EC Chip (Back) too and still no luck!Comment
How about friends, I have this bios from an HP elitebook 840 g9, the problem is that it doesn't give me an image, it just spins the fan quickly, thank you in advance. I need you to change the region or repair.
SN:5CG2351ZR6
PRUDUCT ID: 6D763LT
hi tryAttached FilesComment
Somebody please help me remove password on my hp elitebook 840 g9. thank you so much in advance.
Model: HP ELITEBOOK 840 G9
SN: 5CG3451B30
prodID: 6W5L9UC#UUFAttached FilesComment
Hello It turned out like this for me. At the first boot, reset to factory settings. In the second case, reset the security settings to factory defaults.
I solved it on my own, it turns out that version u71 01.11.05 or higher retains the password, I have downgraded the version to u71 01.10.00 using an ec, and a clean bios, it works perfectly, you just have to write the dmi information later with some mpm tool.
Here I leave you an ec and a clean bios of that version.
PD. Make sure your actual bios is U71 tooAttached FilesComment
i tried this bios and the suggested procedures but still asking for password when i reset the security settings to factory default.Comment
Hi anyone can help
clear this bios
Hp Elitebook 840 g9
Sn: 5CG3311710
Board number: 6050a3417601
thank in advanceAttached FilesComment
Pls Check and reply.Comment
			by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
							Channel: BIOS Requests ONLY!
			This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:50 AM
 - Loading...
