HP hp zbook firefly 14 g7 25Q256 (32mb) Bios PW
  • iaf86
    • Mar 2017
    • 39
    Please help me to unlock HP hp zbook firefly 14 g8 bios
    I'm posting original backup ..
    Thank you
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    Re: HP hp zbook firefly 14 g7 25Q256 (32mb) Bios PW
    Thank you
    your laptop is HP ZBook Firefly 14 G7 Mobile Workstation, bios dump is identical with the one uploaded in thread for HP ZBook Firefly 14 G8 yet you named it different but you posted in wrong places. More like you and they will close bios section because of space occupied with redundant posts.
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      That's right.
      The OP received infraction for this violation, if it happens again he'll receive another one or will be banned to take a break and read the rules.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • kudo623
        • Aug 2022
        • 56
        Please unlock this HP Firefly 14 G7 Bios Thank you!
        Please provide the system information as it looks like all my rear covers
        do not coincide with the motherboard serial number.
        Last edited by SMDFlea; 08-27-2023, 01:50 PM. Reason: bios deleted,posted twice......................
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          Post photo with the label contains DMI. SN from bios is wrong. Can't find on HP site. you didn't even bother the change the name of the dump: firefly14_g8_SN5CG1416V3H-1.bin check if you didn't change covers between them from G7 and G8.
          • kudo623
            • Aug 2022
            • 56
            Sorry we renamed file and included pic confirming BIOS SN as G7
            • volinakis
              • Jan 2021
              • 2875
              • N/A
              you have a way to complicate things, I asked for photo with label containing DMI and you show me something i already know. Try typing SN on hp driver site and see what is happening ... You asked for help but you don't help us with infos required in order to help YOU.
              • kudo623
                • Aug 2022
                • 56
                Hi
                OK sorry here is the label enclosed
                • volinakis
                  • Jan 2021
                  • 2875
                  • N/A
                  Hi
                  everything corresponds with DMI from label but serial.
                  At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
                  Feature Byte: 3X476J6S6b7B7M7Q7U7W7m7saBapaqauawb8bUbhcAdUdpdqfPguhKhkjhk8mE.hE (no spaces)
                  Serial: 5CG1019M60
                  SKU: 37L48US#ABA
                  Build ID: 20WWCMBT601#SABA#DABA
                  Board CT: PJSCT00WBEO2YK
                  Name: HP ZBook Firefly 14 G7
                  Save and use BCU to exit MPM mode or restart laptop/desktop how many times counter shows.
                  REMOVE CMOS BATTERY BEFORE WRITING BIOS!
                  • kudo623
                    • Aug 2022
                    • 56
                      • 22151
                      Is this a different one to the ones youve already asked for. Are you sure about the model numbers this time.You havn`t posted a reply to post #9 for your last request ?
                      • kudo623
                        • Aug 2022
                        • 56
                        Hi. Regarding Post #9:
                        The unlocked bin you provided worked fine. Thank you!
                        This new post #10 is for a different board altogether and it's a G7.
                        hope you can help me unlock it.
                        Thank you.
                        • alfredposadas09
                          • Aug 2020
                          • 342
                          • Philippines
                          Thank you.
                          do you have another bios chip ? can u please take a picture of ur motherboard
                          • volinakis
                            • Jan 2021
                            • 2875
                            • N/A
                            here, same steps as previous, write to DMI what is on the label.
                            Board CT: PJSCT00WBEP1YA
                            • kudo623
                              • Aug 2022
                              • 56
                              Thanks that worked!
                              Initially CAPS LED was solid ON as with the G8 M/B yesterday.
                              I had to push the chip down while soldering it to the M/B to make contact, even though I used paste. I never had that problem with the 128 Winbond chips?
                              • volinakis
                                • Jan 2021
                                • 2875
                                • N/A
                                Thanks that worked!
                                bad contacts happening all the time with WSON chipsets, I personally use a magnifier to check soldering, also I remake contacts with soldering iron before solder chipset with hot air.
                                • kudo623
                                  • Aug 2022
                                  • 56
                                  Hi Thanks for that recommendation! I observed that some boards have solder over the entire copper contacts while some do not. Good advice thank you volinakis!
                                  • Vspeed
                                    • May 2022
                                    • 53
                                    • Portugal
                                    Hey! I have this exact same laptop and I've read this thread but I'm a bit lost. The laptop has 3 flash chips. One 25Q256 which I guess it's the bios and two others. From what I understood, the bios password is stored in one ot the others, which one is it? 25Q80DVIG or 25Q128JVPQ?
                                    I guess after dumping the two required ones, for clearing the pass, you also need the DMI or how you call it (the sticker infomation written on the inside of the bottom lid) or in case I upload the 2nd flash chip dump, you just clear that one and I dont need to input the info from the sticker with the "ARIES MPM TOOL"?
                                    Is there any post explaining the clear method being done here?
                                    edit: found the post I'll read it and try to understand it better.
                                    Thank you.
                                    • alihomee
                                      • Dec 2012
                                      • 1596
                                      • malaysia
                                      i am having same model notebook HP Zbook Firefly 14 g7 with SN:5CG10978YV ...it gives error of hp endpoint security controller every time ....ori file is attached ..hope can be clear from error
                                      • DominicDT
                                        • Aug 2024
                                        • Philippines
                                        Can someone Unlock my Bios for HP Zbook Firefly 14 G7 W25Q256JV
                                        ProdID 8VK86AV
                                        SN# 5CG1045J7S
                                        Warranty 3y3yOy
                                        Build ID:20WWCMBT601#SABU#DABU
                                        Feature Byte: 3X476J6S6b7B7M7R7U7W7m7saBaEapaqauawbUbhcAdUdpdqfPgSguhKjhk8mE.qf
                                        I really thought I removed the password by editing using HxD but I got this:
                                        ​ Click image for larger version
                                          SMDFlea commented
                                          Editing a comment
                                          Post moved to Firefly 14 G7 thread.
                                        HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
                                        This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                        09-07-2024, 05:20 AM
                                      • capsandpots
                                        Need BIOS unlocked for HP ZBook Firefly 14 G10A AMD Processor version
                                        by capsandpots
                                        Hello
                                        Need BIOS unlocked
                                        HP ZBook Firefly G10A AMD version
                                        Both chips dump below
                                        SN: 5CG41818RH
                                        Thanks so much ...
                                        01-05-2025, 12:46 AM
                                      • CeeEee4
                                        HP ZBOOK FIREFLY 14 G10 A (AMD) Corrupt BIOS
                                        by CeeEee4
                                        Hello
                                        I have an HP ZBOOK FIREFLY 14 G10 A (AMD) model with HP Blink Error 2-2 (Main area DXE of BIOS has become corrupted and no binary recovery image available.) I have tried BIOS recovery USB but it didnt work.
                                        Tried using a "clean" bin extracted from the HP softpaq but laptop would not even respond to power button, although it had white LED on DC jack.
                                        Here is back up of the BIOS, hope somebody can help. Thanks
                                        09-16-2025, 09:07 AM
                                      • zlr8r
                                        Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                        by zlr8r
                                        Greetings
                                        I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                        Serial Number: 5CG3202C16
                                        Product #/SKU: 739P0AV
                                        CT Number: PRTUE00WBI30YX
                                        Description: HP ZBook Firefly 14 inch G10
                                        BuildID: 23WWWGAZ602#SABU#DABU
                                        Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                        MAC address not found.
                                        • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                        10-28-2025, 01:56 PM
                                      • beal
                                        bios hp ZBook Firefly 14 inch G9
                                        by beal
                                        hi
                                        Please Bios hp ZBook Firefly 14 inch G9
                                        FF14-MV-GCE 6050A3310001-MB-A01
                                        SN : 5CG31412Q7
                                        thanks...
                                        09-03-2025, 09:55 AM
