Lenovo Thinkpad L15 gen 1 Bios Request
  • Hachem25
    • Aug 2021
    • 45
    • algeria
    I HAVE THINKPAD L15 GEN 1. SN:TP00121A. IT BEEPS ON SRATARTUP AND DSPLAYS NOTHING. IF YOU CAN HELP ME
    • Buffalotoast
      • Aug 2023
      • 6
      Originally posted by Maxpower3
      There are password chunks left after the usual location​
      I think it's good today, I understood
      Cliquez sur l'image pour la voir en taille r?elleÃÃÃÃÃÃà Nom : 		image.pngÃÃÃÃÃÃà Affichages :	0ÃÃÃÃÃÃà Taille :		925,6 KoÃÃÃÃÃÃà ID : 			3461597
      Cliquez sur l'image pour la voir en taille r?elleÃÃÃà Nom : 		image.pngÃÃÃà Affichages :	0ÃÃÃà Taille :		346,4 KoÃÃÃà ID : 			3461603
      edit try file 2 , 1 must not work
      Hi, trying to erase the supervisor password on a ThinkPad L15 gen 1 as well.
      I found the three areas (3C420-3C45F, 3D420-3D45F, 3CC20-3CC3F), which contained the password or part of it. I cleared with with 00 or FF and still get "SVP error" on boot. Can you share your knowledge from the last post please? I dont seem to understand.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1226
        • France
        post your dump
        • Buffalotoast
          • Aug 2023
          • 6
          Ah, sorry. I figured I could have done that right away. I compared the files and it seems, I dont have the list in the 3D620 range. Also, I should mention, I tried your "shorting method" without success before. Dont know if that might have corrupted some data.
          SN PF-1VEWD0
          TN 20U4-S09200
          Your "try2.bin" did not work. Did not boot. Possible due to bad SN
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            try this
            It's late at my place, not much time. I'll see tomorrow otherwise​
            • Buffalotoast
              • Aug 2023
              • 6
              try this
              Thank you for the effort. Sadly I forgot to disconnect bios battery and flashing went wrong. Seems like I bricked the EC firmware. Laptop doesnt start anymore and EC is not detected by SVOD4. I will have to buy a new chip probably or try an out of chassis adapter. I tried to reset the board (no charger, no battery etc)
              Edit: I am sorry for the confusion. I am fairly new to working with EC firmware. Without a battery plugged while trying to connect, the EC was recognized again. For me that is odd as the NPCE68APA was only working with SVOD4 with battery connected. I was able to flash your data succesfully now, but I still got "bad SVP data".
              • Buffalotoast
                • Aug 2023
                • 6
                try this
                I reviewed your file and saw that I made an error before and erased too little. Thank you for correcting my mistake!
                Bit of back story: laptop had "bottom cover tempered" error before playing with EC firmware. Do you think that is still in firmware hidden? And maybe is our problem?
                Also I saw you provided a lot of files for other guys in this topic. It was nice to follow your process of thought on these. Did you ever get feedback from ppl that a removed pw section in EC firmware succesfully cleared the supervisor pw?
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1226
                  • France
                  #28
                  search in the L14 subjects, I think it worked once.
                  This EC model is complicated and no one tries to clean it except me.
                  Shame.
                  I don't have time today but I'll try again if you want
                  NM-C741 NCPE68AP??
                  ​However, I managed to get this model on YouTube
                  • Buffalotoast
                    • Aug 2023
                    • 6
                    Shame.
                    NM-C741 NCPE68AP??
                    Hey, sorry for delay. I would appreciate if you tried the pw removal again. I dont see a point on what to change in the file again.
                    Do you have experience with flashing a 'clean' EC file from a different SN laptop? Found clean EC file for a L14 i5 10th gen
                    Model# NM-C631 with NPCE68APA
                    I wasnt able to get it to boot with shorting. Always been stuck on logo.
                    • Buffalotoast
                      • Aug 2023
                      • 6
                      Do not want to spam, but more to share my findings.
                      Booting with your cleaned EC resulted in a different EC file. I read it again and it seems that the EC is alter in one of the pw spots
                      I tested the L14_clean_EC.bin and was able to boot, but "system configuration is invalid" is showing up everytime. I will try to rebuild my original file with the L14 one and give it a try.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        #31
                        https://www.badcaps.net/forum/troubl...92#post3537692
                        • Commannn10
                          • May 2025
                          • Romania
                          #32
                          UEFI BIOS CAN'T CHANGE, SECURE BOOT ENABLE, i want to disable it, PASSWORD BIOS : 12345 (I put it because I thought that at that moment it would unlock my secure boot option)
                          SERIAL NUMBER : PF-3CYP2T
                          TYPE NUMBER : 20U4-S2QH00
                          if you can help me. thank you very much
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11738
                            #33
                            Try
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1226
                              • France
                              #34
                              maybe look for Kernel DMA if for change to UEFI/legacy boot settings
                              • 1g0r
                                Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                by 1g0r
                                First, the data in brief:
                                Manufacturer: Lenovo
                                Model: ThinkPad L15 G3 21C3-0016GE
                                motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                IC Bios 1: MX77L25650F
                                IC Bios 2​: MX25L25673G
                                EC Chip: NPCX997KAABX
                                So far I've been a silent reader, but now I need your help
                                I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                01-18-2025, 02:39 AM
                              • MaxonDomkrat
                                Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                by MaxonDomkrat
                                Hi everyone.
                                I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                07-30-2025, 01:27 PM
                              • RMDUiFT
                                Should I buy a Lenovo Thinkpad E495 with bios password?
                                by RMDUiFT
                                Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                I have a few questions:
                                • If I would buy this laptop and have
                                08-25-2024, 09:00 AM
                              • akwky
                                by akwky
                                Hi!
                                04-14-2025, 01:56 PM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
