X415UA r2.0 bios need help
  • jaglion19
    • Oct 2017
    • 102
    • TURKEY
    Good luck to everyone, I need Asus D515UA case code, X415UA R.20 bios AMD Ryzen 5, if you have it can you share it? thank you in advance
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: X415UA r2.0 bios need help
    Upload your bios backup, add issue description and clear picture of the white sticker with the barcode/QR code on it.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • jaglion19
      • Oct 2017
      • 102
      • TURKEY
      I have attached the original bios dump. device asus text comes on, then the black screen stays. I shook the cpu. same again
      • Haker5
        Banned
        • Mar 2015
        • 65
        • internet
        check and raport
          • 21606
          Is there a QR code next to the heatsink bracket or somewhere else, if there is post a picture of it.
          • jaglion19
            • Oct 2017
            • 102
            • TURKEY
            Originally posted by Haker5
            check and raport
            thanks it works 100%
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • ngngocson113
              I need bios asus tp301u ( uma ( vga share))
              by ngngocson113
              hi everyone
              i need bios asus tp301uj ( "uma " vga share)
              my mainboard doesn't use vga chip and it uses vga together with cpu.
              I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
              thanks everyone....
              09-25-2025, 02:20 AM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
