I need bios asus tp301u ( uma ( vga share))
  • ngngocson113
    • Jan 2022
    • 34
    • viet nam
    hi everyone
    i need bios asus tp301uj ( "uma " vga share)
    my mainboard doesn't use vga chip and it uses vga together with cpu.
    I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
    thanks everyone.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12407
    Originally posted by ngngocson113
    hi everyone
    thanks everyone.
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
