I have a problem with this board, it doesn't power's on at all , i have all the right voltages, the power button sends a signal to the MEC CHIP but nothing happends, i have flashed bios chip 3 times with 3 different versions but nothing, has anyone got a dump of the MEC1416 CHIP?
Mlk kbl-r 17841-1 wx2rr mec1416 dump needed
Re: Mlk kbl-r 17841-1 wx2rr mec1416 dump needed
https://www.badcaps.net/forum/showth...416#post999329
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by MephysisHello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"? -
by dell_biosHi everyone,
I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
The board has three SPI flash chips:
- W25Q64FV (main BIOS)
- W25Q32FV (EC/TPM)
- W25X10CL (configuration)
I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
The dump contains protection that needs to be removed.
If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
I’m also happy to share my dump for comparison if needed.
Laptop model: [please specify, e.g....-
- Loading...
