Need Bios For IdeaPad 3 15IAU7
  • BOGOSY77
    • Aug 2018
    • 50
    • PITON
    #61
    Originally posted by AHSAN TARIQ
    try this and u[date
    Can you spilt the file in 2 different bin file?
    Thanks,
    • Stefan Steff
      • Mar 2024
      • 345
      • Romania
      #62
      Splitted
      • BOGOSY77
        • Aug 2018
        • 50
        • PITON
        #63
        Originally posted by Stefan Steff
        Splitted
        AHSAN TARIQ and Stefan Steff the Bios start the laptop, show display said bios recovery bar status do not shutdown, but after that shutdown by itself and No more display after that.
        Display 1 time oly. now no.
        • Stefan Steff
          • Mar 2024
          • 345
          • Romania
          #64
          I've just split the file provided by AHSAN TARIQ ...I didn't make it...
          ...but here some file made by me, so test and provide feedback.
          • BOGOSY77
            • Aug 2018
            • 50
            • PITON
            #65
            Hi, now no power at all with this bios.
            • Stefan Steff
              • Mar 2024
              • 345
              • Romania
              #66
              OK, I have another build prepared for you and if this isn't working for you the maybe some other forum member will help you out.
              If a build isn't working always write back the original to assure you didn't blow away a component or you don't pick up by mistake a component with the soldering iron...
              Good Luck!
              • BOGOSY77
                • Aug 2018
                • 50
                • PITON
                #67
                Good Luck!
                No luck with your bios, no power.
                But I found this two bios, its power on the laptop, keyboard light flash once, fan turn then all stop, boot loop like that no display,
                repeat and repeat.
                Can you clear me the bios 8mb
                or rebuild both? thanks
                I send you
                • ministeri
                  • Mar 2020
                  • 4
                  • Italia
                  #68
                  Hi everyone, I have a Lenovo ideapad 3 15iau7 main board NM-E341 PC which showed no signs of life, I found the PC1502 and the PQ 5400 short circuited, replaced the faulty components and now the PC turns on, draws 600 but does not boot, black video, 3 LEDs on the keyboard are on. I checked the 2nd bios chip and the UB3 W25Q128 eeprom chip was unreadable, while I was able to read the UB2 W25R64 eeprom. I replaced the UB3 W25Q128 with a new one, I extracted the bios from the Lenovo site by putting the PC serial number PF4HXNHB, I extracted the 2 flashed files in the 2 eeproms but it continues to present the same problem.
                  +1.6V_VCCCORE gives only 0.8 volts
                  +1.5V_VCCGT absent 0 volts,
                  +1.8V_VCCIN_AUX is ok 1.8 volts
                  I tried other bios downloaded from the site but none of them work.
                  Any advice?
                  any help?
                  • ministeri
                    • Mar 2020
                    • 4
                    • Italia
                    #69
                    The translator mistranslated: It draws 600 mA
                    • wo5102586
                      • Jan 2024
                      • 24
                      • IRELAND
                      #70
                      hi everybody, I got a laptop with a non-working onboard memory, could someone help to disable the onboard memory through editing the bios?
                      my old bios is in attached.
                      i'll really aperaciate it! thank you!
                      motherboard: JV473 & JV573 & JS478 & JS578 & JS778
                      NM-E341
                    • akozyura
                      • Oct 2025
                      • 4
                      • Ukraine
                      #71
                      Hello dear Friends,
                      Please can you fix this bios ideapad 3 15iau7 (NM-E341)
                      SN# PF4QJ8H2
                      I tried peste files in post#5 but it didn't work.
                      I tried to extract bios from lenovo website and i inserted DMI informations but i think i missed a thing.
                      I am attaching the dumps I read.
                      thanks
                      • m1ch43lzm
                        • Mar 2019
                        • 799
                        • Peru
                        #72
                        Originally posted by akozyura
                        Hello dear Friends,
                        SN# PF4QJ8H2
                        thanks
                        Try, DMI inserted
                        IdeaPad 3 15IAU7 Laptop - Type 82RK
                        S/N PF4QJ8H2
                        MTM 82RK012LRA
                        ​BIOS ver JKCN41WW
                        • akozyura
                          • Oct 2025
                          • 4
                          • Ukraine
                          #73
                          Originally posted by m1ch43lzm
                          Try, DMI inserted
                          S/N PF4QJ8H2
                          MTM 82RK012LRA
                          BIOS ver JKCN41WW
                          I flashed it, the LED lights up, the fans don't spin, the display doesn't light up, and I can see the BIOS reading from the chips on the oscilloscope. Most likely, there are still problems with the motherboard, I'll check the voltages more thoroughly,
                          Thank you very much!
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • jendkkd jeje
                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                            by jendkkd jeje
                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                            10-11-2024, 03:12 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • joven016
                            Lenovo Ideapad S145 need working bios HELP!!
                            by joven016
                            Problem is blinking power led only
                            i don't know exactly if it's s145-15igm or s145-14igm
                            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                            Already tested some of posted bios here
                            S145-14igm - success but invalid serial and not booting on OS
                            S145-15igm - success with serial and some other info in bios but still not booting on OS
                            already tried installing new windows but always booting on bios setup
                            windows installer flash drive detected on...
                            08-21-2025, 10:55 PM
                          • Fr33man
                            BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                            by Fr33man
                            I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                            *Novo button power on
                            *Disconnected internal battery...
                            09-23-2024, 01:16 PM
