Need Bios For IdeaPad 3 15IAU7
AHSAN TARIQ and Stefan Steff the Bios start the laptop, show display said bios recovery bar status do not shutdown, but after that shutdown by itself and No more display after that.
Display 1 time oly. now no. Comment
I've just split the file provided by AHSAN TARIQ ...I didn't make it...
...but here some file made by me, so test and provide feedback.
Attached FilesComment
Hi, now no power at all with this bios.
...but here some file made by me, so test and provide feedback.Comment
OK, I have another build prepared for you and if this isn't working for you the maybe some other forum member will help you out.
If a build isn't working always write back the original to assure you didn't blow away a component or you don't pick up by mistake a component with the soldering iron...
Good Luck!Attached FilesComment
No luck with your bios, no power.
Good Luck!
But I found this two bios, its power on the laptop, keyboard light flash once, fan turn then all stop, boot loop like that no display,
repeat and repeat.
Can you clear me the bios 8mb
or rebuild both? thanks
I send youAttached FilesComment
Hi everyone, I have a Lenovo ideapad 3 15iau7 main board NM-E341 PC which showed no signs of life, I found the PC1502 and the PQ 5400 short circuited, replaced the faulty components and now the PC turns on, draws 600 but does not boot, black video, 3 LEDs on the keyboard are on. I checked the 2nd bios chip and the UB3 W25Q128 eeprom chip was unreadable, while I was able to read the UB2 W25R64 eeprom. I replaced the UB3 W25Q128 with a new one, I extracted the bios from the Lenovo site by putting the PC serial number PF4HXNHB, I extracted the 2 flashed files in the 2 eeproms but it continues to present the same problem.
+1.6V_VCCCORE gives only 0.8 volts
+1.5V_VCCGT absent 0 volts,
+1.8V_VCCIN_AUX is ok 1.8 volts
I tried other bios downloaded from the site but none of them work.
Any advice?
any help?
ThanksComment
hi everybody, I got a laptop with a non-working onboard memory, could someone help to disable the onboard memory through editing the bios?
my old bios is in attached.
i'll really aperaciate it! thank you!
motherboard: JV473 & JV573 & JS478 & JS578 & JS778
NM-E341
The Serial number, SNID or Service Tag must be posted with all bios requests -> https://www.badcaps.net/forum/troubl...before-posting
Try the ram patcher script or search on google for the SPD removal tool -> https://www.badcaps.net/forum/troubl...20#post3232220
Hello dear Friends,
Please can you fix this bios ideapad 3 15iau7 (NM-E341)
SN# PF4QJ8H2
I tried peste files in post#5 but it didn't work.
I tried to extract bios from lenovo website and i inserted DMI informations but i think i missed a thing.
I am attaching the dumps I read.
thanksAttached FilesComment
Try, DMI insertedHello dear Friends,
SN# PF4QJ8H2
thanks
IdeaPad 3 15IAU7 Laptop - Type 82RK
S/N PF4QJ8H2
MTM 82RK012LRA
BIOS ver JKCN41WW
I flashed it, the LED lights up, the fans don't spin, the display doesn't light up, and I can see the BIOS reading from the chips on the oscilloscope. Most likely, there are still problems with the motherboard, I'll check the voltages more thoroughly,
Thank you very much!Comment
Здравствуйте! У меня проблема такая же как у ministeri из поста 68. Имею Lenovo ideapad 3 15iau7 NM-E341, при подаче питания происходит самовключение, потребление около 660 mA, инициализации нет, 3 светодиода на клавиатуре включены, а светодиод кнопки включения начинает сразу мигать, кулер крутит секунд 5 и останавливается. Долгое удержание кнопки питания выключает ноутбук. Пробовал шить Bios и EC чистым с сайта и другим дампом, ноутбук ведёт себя так же.
Замеры питаний в норме, кроме: +1,6V_VCCCORE которое 0,82 V и +1,5V_VCCGT которое 0 V
Hello! I have the same problem as ministeri from post 68. I have a Lenovo ideapad 3 15iau7 NM-E341, when power is applied it turns on automatically, consumption is about 660 mA, there is no initialization, 3 LEDs on the keyboard are on, and the power button LED starts blinking immediately, the cooler spins for 5 seconds and stops.
Long-pressing the power button turns off the laptop. I tried to flash Bios and EC clean from the site and another dump, the laptop behaves the same.
Power measurements are normal, except for: +1.6V_VCCCORE which is 0.82 V and +1.5V_VCCGT which is 0 VComment
Hi EvGeniy, could you tried this bios and ec files. Hope can give some light for youЗдравствуйте! У меня проблема такая же как у ministeri из поста 68. Имею Lenovo ideapad 3 15iau7 NM-E341, при подаче питания происходит самовключение, потребление около 660 mA, инициализации нет, 3 светодиода на клавиатуре включены, а светодиод кнопки включения начинает сразу мигать, кулер крутит секунд 5 и останавливается. Долгое удержание кнопки питания выключает ноутбук. Пробовал шить Bios и EC чистым с сайта и другим дампом, ноутбук ведёт себя так же.
[ЦИТАТА=хайрулоле;n3749940]
Привет, ЕвГений, не могли бы вы попробовать эти файлы Bios и EC. Надежда может дать вам свет [/ЦИТАТА]
Я попробовал эти файлы, без изменений. Вот мой родной дамп
I tried these files, no change. Here is my original dumpAttached FilesComment
Please, only ENGLISH[ЦИТАТА=хайрулоле;n3749940]
Я попробовал эти файлы, без изменений. Как добавить свои файлы на форум?
I tried these files, no change. How to add your files to the forum?Comment
Hi, I also tried the Bios posted by Hairulole in post 75 but it doesn't work, same problem: 3 keyboard LEDs on, fan running for a few seconds and 600 Ma of absorption. The serial number of my PC (PF4HXNHB). A huge thank you to anyone who can help usComment
post S/N, full name and model, motherboard model, ,TYPE,etc.
post the contents of the bios chip even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hi, sorry, I'm posting the summary of my model: Lenovo ideapad 3 15iau7 NM-E341 serial number: PF4HXNH. I attach my files, they are .bin files, just delete the .rar. ThanksComment
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
Today, 04:20 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
- Loading...
