Need Bios For IdeaPad 3 15IAU7
  • BOGOSY77
    • Aug 2018
    • 20
    • PITON
    #61
    Originally posted by AHSAN TARIQ
    try this and u[date
    Can you spilt the file in 2 different bin file?
    Thanks,
    • Stefan Steff
      • Mar 2024
      • 245
      • Romania
      #62
      Splitted
      • BOGOSY77
        • Aug 2018
        • 20
        • PITON
        #63
        Originally posted by Stefan Steff
        Splitted
        AHSAN TARIQ and Stefan Steff the Bios start the laptop, show display said bios recovery bar status do not shutdown, but after that shutdown by itself and No more display after that.
        Display 1 time oly. now no.
        • Stefan Steff
          • Mar 2024
          • 245
          • Romania
          #64
          I've just split the file provided by AHSAN TARIQ ...I didn't make it...
          ...but here some file made by me, so test and provide feedback.
          • BOGOSY77
            • Aug 2018
            • 20
            • PITON
            #65
            Hi, now no power at all with this bios.
            • Stefan Steff
              • Mar 2024
              • 245
              • Romania
              #66
              OK, I have another build prepared for you and if this isn't working for you the maybe some other forum member will help you out.
              If a build isn't working always write back the original to assure you didn't blow away a component or you don't pick up by mistake a component with the soldering iron...
              Good Luck!
              • BOGOSY77
                • Aug 2018
                • 20
                • PITON
                #67
                Good Luck!
                No luck with your bios, no power.
                But I found this two bios, its power on the laptop, keyboard light flash once, fan turn then all stop, boot loop like that no display,
                repeat and repeat.
                Can you clear me the bios 8mb
                or rebuild both? thanks
                I send you
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • jendkkd jeje
                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                  by jendkkd jeje
                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                  10-11-2024, 03:12 PM
                • mximiliandz
                  help bios lenovo ideapad s145-14iil type 81w6
                  by mximiliandz
                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                  06-20-2025, 06:50 AM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • Fr33man
                  BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                  by Fr33man
                  I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                  *Novo button power on
                  *Disconnected internal battery...
                  09-23-2024, 01:16 PM
