HP 840 G8 Bios Unlock
first boot press f10 apply factory defaults and exit. use BCU.
Serial Number: 5CG3061WYQ
Product Number: 4E0Q1EC#ACH
CT Number: PQSMT00WBHP29C
Description: HP EliteBook 840 G8 Notebook
BuildID: 21WWCVET601#SACH#DACH
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfPguhKhkjhk8mEmVn7nVngpDpq.h2
MAC Address : 7C:4D:8F:3F:85:02Attached FilesComment
Please unlock...swat lock
Serial Number: 5CG22817KG
Product Number: 509H3UC#UUF
BuildID: 21WWCVET601#SUUF#DUUF
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4gAttached FilesComment
First boot apply factory defaults and exit, 2nd boot reset security settings to defaults and exit.
Use BCU fill these DMI info:
CT Number: PQSNT00WBGUJ08
MAC Address : 5C:60:BA:C8:08:E4Attached FilesComment
Please unlock...
Serial Number: 5CG1480DDG
Product Number: 4U4B8US#ABAAttached FilesComment
It worked, thank you very much, I just learned how to crack passwords using EC files, I wonder if passwords can be broken using one of two files, it's true that the more I learn, the more stupid I feel :vComment
Originally posted by minhdigital View Post
Send to you, first boot press f10 apply factory defaults and exit. use BCU.
how to remove passwords using ec chip? please share so we can learn as well.
Thank youComment
Thank youAttached FilesLast edited by rex98; 04-16-2024, 04:48 AM.Comment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello.
Can you clear my BIOS password?
Model: HP EliteBook 840 G8
S/N: 5CG211CBF2
Board-Model: 6050A3426501-MB-A02
ProdID: 4Y9T4EC#ABB
Chip-model: Winbond 25Q256JVEN
I have two bios dump files.
Top of board and bottom of boardAttached FilesLast edited by Deeloc; 05-27-2024, 01:51 AM.Comment
use BCU. you can permanently disable Absolute lock in BCU.
here's your DMI:
Serial Number: 5CG211CBF2
Product #/SKU: 4Y9T4EC#ABB
CT Number: PQSNL00WBGEWDB
BuildID: 21WWCVET601#SABB#DABB
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfPguhKhkj4jhk8mEmwn7nVngpDpq.MB
MAC Address : 3C:18:A0:C8:8B:7BComment
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
here's your DMI:
Big thanks Comment
Please I would like to clean the Bios password!
SN_5CG1501WR2Attached FilesComment
here's your DMI:
Serial Number: 5CG1501WR2
Product #/SKU: 26D60AV
CT Number: PKUHC00WBG111S
BuildID: 21WWCVCT602#SABD#DABD
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwnVngpD.Bh
MAC Address : C0:18:03:2D:A1:07Attached FilesComment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
by AkaBukaiHi there,
I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
The little LED on the power button is flashing slowly and nothing happen.
This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
So I decided to flash the BIOS using a cheap programmer.
And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
I also... -
by what_1282105Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
- Loading...
