Lenovo Legion S7 15ACH6
Every donation made will go towards server fees and maintenance costs. -
Serial Number: PF31VQ4K
Motherboard Model: BM5070_V1.4
Edit: Found the On Board RAM Disable script; Fingers crossed that this works.
Edit2: Did not work. All voltage rails are present but CPU and GPU do not get hot. No shorts are present and resistances on all rails are good. Using known good slotted RAM and the fans spin with keyboard lights, but no POST.Last edited by ResoluteHawk; 11-30-2024, 02:10 PM.Comment
Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I put the BIOS that you posted through the disable RAM script and flashed it; I'm still running into the same problem.
If this script is actually doing what it's supposed to be doing, then I'm likely running into a problem with a dead chipset/APU, but this diagnosis doesn't make sense since all voltage rails are present with good resistances.
CPU and GPU are getting slightly warm but nowhere as hot as they should be for system power on, and the system is running for 5+ minutes. CPU and GPU VCORE voltages are present.
I have no other ideas at this point.Last edited by ResoluteHawk; 12-02-2024, 09:20 AM.Comment
ECAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Thanks for the reply.
Just to clarify: this laptop has already been through multiple repair shops, and several different BIOS files have been flashed to it — none of them worked. Unfortunately, in the country I live in, getting access to verified BIOS files is very difficult due to various limitations.
At this point, I'm only looking for a verified, clean BIOS dump that exactly matches my machine:
- Model: Lenovo Legion S7 15ACH6
- Serial Number: PF2XWM03
If you or anyone else has a known-good dump from a working unit of the same model, I would be truly grateful. Honestly, I had given up on this laptop — but today I decided to give it one last try and reach out here for help.
Thanks again for your time and support.Comment
https://www.badcaps.net/forum/troubl...h6#post1824992Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Legion S7-15ACH6 Laptop (Lenovo) - Type 82K8
SN: PF375S3Q
Motherboard Model: LENOVO LNVNB161216
Bios Version: HACN46WW
If possible, may I request the previous BIOS version? Right now, my laptop is unable to detect peripheral devices on both USB-C ports on the right side. I have already tried many things, such as updating drivers, performing a soft reset (holding the button for 30 seconds), and installing a fresh copy of Windows.
The odd thing is, I’m still able to use USB-C to charge the laptop with a 100W charger. Also, if I connect a USB-C hub powered by a 100W supply, I’m able to use peripheral devices. However, when in the BIOS settings, the USB-C ports are unable to detect anything.
Thanks in advance.
SN: PF375S3Q
Thanks in advance.
I don’t have other USB-C ports on this laptop—only the two on the right side, and both are experiencing the same issue. The USB-A ports at the back are working fine. Since this problem started after the BIOS update, I would like to request the previous BIOS version to check if that resolves the issue.Comment
https://download.lenovo.com/consumer...s/hacn39ww.exe
https://download.lenovo.com/consumer...s/hacn42ww.exe
https://download.lenovo.com/consumer...s/hacn43ww.exe
The trick is to rename the download link, sometimes that won't work anymore as Lenovo removes old versions from their website
But I don't think it's a BIOS issue, it may be hardware problem such as dirty/oxidized contacts/moisture on the ports themselves, get a USB-C voltage testerLast edited by m1ch43lzm; 09-04-2025, 11:00 AM.Comment
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
This specification for the Lenovo Legion S7 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S7 15ACH6 boardview and S7 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
This specification for the Lenovo Legion 5 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ACH6 boardview and 5 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 04:30 AM
by JarJarBinksLaptop was powered off during BIOS update. Laptop turns on, keyboards lights up, and then just beeps over and over into infinity until powered off.
Model: Lenovo Legion 5 15ACH6 Type 82JW
S/N: PF30P6DN
Attached is the BIOS dump from the laptop and the latest BIOS update from Lenovo.
I searched and I don't believe this particular bios has been posted. I attempted to the follow directions
on the BIOS guides page but I am brand new to this and the update file doesn't seem to match
the bios dump in size so I am at a loss on what to do to...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM - Loading...
