Originally posted by ResoluteHawk
View Post
Lenovo Legion S7 15ACH6
Serial Number: PF31VQ4K
Motherboard Model: BM5070_V1.4
Edit: Found the On Board RAM Disable script; Fingers crossed that this works.
Edit2: Did not work. All voltage rails are present but CPU and GPU do not get hot. No shorts are present and resistances on all rails are good. Using known good slotted RAM and the fans spin with keyboard lights, but no POST.Last edited by ResoluteHawk; 11-30-2024, 02:10 PM.
Become a Badcaps supporter
Thanks to all supporters.
I put the BIOS that you posted through the disable RAM script and flashed it; I'm still running into the same problem.
If this script is actually doing what it's supposed to be doing, then I'm likely running into a problem with a dead chipset/APU, but this diagnosis doesn't make sense since all voltage rails are present with good resistances.
CPU and GPU are getting slightly warm but nowhere as hot as they should be for system power on, and the system is running for 5+ minutes. CPU and GPU VCORE voltages are present.
I have no other ideas at this point.Last edited by ResoluteHawk; 12-02-2024, 09:20 AM.
Originally posted by tuthanh View PostHELP ME BIOS EC BM5070 V1.4 (ITE 5576-128)
Originally posted by tuthanh View Postlegion s7 15ACH6
S\N:PF3K62FJ
VER:BM5070_V1.4
ThanksAttached Files
