Lenovo Legion S7 15ACH6
  • peste
    • Dec 2016
    • 12655
    • ROMANIA
    Originally posted by ResoluteHawk
    Hi! If possible, I need to disable the onboard RAM as it has issues with the solder joints under one or more of the chips.
    My customer is not going to want to pay for reballing the onboard RAM or replacing it, so if there is a way to just disable the onboard memory I'm sure they will be ok with it and they can just buy higher capacity slotted RAM.
    Thanks.
    post the S/N, the motherboard model, the full name and model of the laptop,etc.
    • ResoluteHawk
      • Nov 2021
      • 153
      Serial Number: PF31VQ4K
      Motherboard Model: BM5070_V1.4
      Edit: Found the On Board RAM Disable script; Fingers crossed that this works.
      Edit2: Did not work. All voltage rails are present but CPU and GPU do not get hot. No shorts are present and resistances on all rails are good. Using known good slotted RAM and the fans spin with keyboard lights, but no POST.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11651
        Legion S7-15ACH6 Laptop (Lenovo) - Type 82K8
        • ResoluteHawk
          • Nov 2021
          • 153
          Thank you! I'll give this a shot on Monday.
          • ResoluteHawk
            • Nov 2021
            • 153
            I put the BIOS that you posted through the disable RAM script and flashed it; I'm still running into the same problem.
            If this script is actually doing what it's supposed to be doing, then I'm likely running into a problem with a dead chipset/APU, but this diagnosis doesn't make sense since all voltage rails are present with good resistances.
            CPU and GPU are getting slightly warm but nowhere as hot as they should be for system power on, and the system is running for 5+ minutes. CPU and GPU VCORE voltages are present.
            I have no other ideas at this point.
            • tuthanh
              • Dec 2022
              • hcm
              #26
              HELP ME BIOS EC BM5070 V1.4 (ITE 5576-128)
                • 20701
                https://www.badcaps.net/forum/troubl...before-posting post your laptop serial number
                • tuthanh
                  • Dec 2022
                  • hcm
                  #28
                  legion s7 15ACH6
                  S\N:PF3K62FJ
                  VER:BM5070_V1.4
                    • 20701
                    legion s7 15ACH6
                    S\N:PF3K62FJ
                    VER:BM5070_V1.4
                    EC
                    • Navid_AJR
                      • May 2025
                      • Iran
                      #30
                      Same issue for me. My laptop got a power failure during bios updating and now it won't power on at all.
                      S/N: PF2XWM03
                      Thak you in advance.
                      • peste
                        • Dec 2016
                        • 12655
                        • ROMANIA
                        #31
                        S/N: PF2XWM03
                        post the contents of the bios chip even if it is corrupted..
                        • Navid_AJR
                          • May 2025
                          • Iran
                          #32
                          Thanks for the reply.
                          Just to clarify: this laptop has already been through multiple repair shops, and several different BIOS files have been flashed to it — none of them worked. Unfortunately, in the country I live in, getting access to verified BIOS files is very difficult due to various limitations.
                          At this point, I'm only looking for a verified, clean BIOS dump that exactly matches my machine:
                          - Model: Lenovo Legion S7 15ACH6
                          - Serial Number: PF2XWM03
                          If you or anyone else has a known-good dump from a working unit of the same model, I would be truly grateful. Honestly, I had given up on this laptop — but today I decided to give it one last try and reach out here for help.
                          Thanks again for your time and support.​
                          • peste
                            • Dec 2016
                            • 12655
                            • ROMANIA
                            #33
                            you have everything you need at post #6..
                            https://www.badcaps.net/forum/troubl...h6#post1824992
                            • grimacelord
                              Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                              by grimacelord
                              Hello there.
                              I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                              History:
                              1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                              I searched for this error online and discovered...
                              03-15-2023, 03:29 PM
                              Lenovo Legion S7 15ACH6 Notebook Specification for Upgrade or Repair
                              This specification for the Lenovo Legion S7 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S7 15ACH6 boardview and S7 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                              09-07-2024, 05:00 AM
                              Lenovo Legion 5 15ACH6 Notebook Specification for Upgrade or Repair
                              This specification for the Lenovo Legion 5 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ACH6 boardview and 5 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                              09-07-2024, 04:30 AM
                            • JarJarBinks
                              Need BIOS BIN for Lenovo Legion 5 15ACH6 Type 82JW
                              by JarJarBinks
                              Laptop was powered off during BIOS update. Laptop turns on, keyboards lights up, and then just beeps over and over into infinity until powered off.
                              Model: Lenovo Legion 5 15ACH6 Type 82JW
                              S/N: PF30P6DN
                              Attached is the BIOS dump from the laptop and the latest BIOS update from Lenovo.
                              I searched and I don't believe this particular bios has been posted. I attempted to the follow directions
                              on the BIOS guides page but I am brand new to this and the update file doesn't seem to match
                              the bios dump in size so I am at a loss on what to do to...
                              01-01-2024, 03:15 PM
                            • sugih1211
                              request for bios bin lenovo legion 5-15ach6
                              by sugih1211
                              hi admin and all. can please give a clean boot bios bin for lenovo legion 5-15ach hy56w hy66w hy76w nm-d931 rev 1.0 cause my legion on but no display. thanks very much.
                              08-20-2024, 11:52 PM
