Lenovo Legion S7 15ACH6
  • peste
    • 13599
    • ROMANIA
    Originally posted by ResoluteHawk
    Hi! If possible, I need to disable the onboard RAM as it has issues with the solder joints under one or more of the chips.
    My customer is not going to want to pay for reballing the onboard RAM or replacing it, so if there is a way to just disable the onboard memory I'm sure they will be ok with it and they can just buy higher capacity slotted RAM.
    Thanks.
    post the S/N, the motherboard model, the full name and model of the laptop,etc.
    • ResoluteHawk
      • Nov 2021
      • 154
      Serial Number: PF31VQ4K
      Motherboard Model: BM5070_V1.4
      Edit: Found the On Board RAM Disable script; Fingers crossed that this works.
      Edit2: Did not work. All voltage rails are present but CPU and GPU do not get hot. No shorts are present and resistances on all rails are good. Using known good slotted RAM and the fans spin with keyboard lights, but no POST.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12330
        Legion S7-15ACH6 Laptop (Lenovo) - Type 82K8
        • ResoluteHawk
          • Nov 2021
          • 154
          Thank you! I'll give this a shot on Monday.
          • ResoluteHawk
            • Nov 2021
            • 154
            I put the BIOS that you posted through the disable RAM script and flashed it; I'm still running into the same problem.
            If this script is actually doing what it's supposed to be doing, then I'm likely running into a problem with a dead chipset/APU, but this diagnosis doesn't make sense since all voltage rails are present with good resistances.
            CPU and GPU are getting slightly warm but nowhere as hot as they should be for system power on, and the system is running for 5+ minutes. CPU and GPU VCORE voltages are present.
            I have no other ideas at this point.
            • tuthanh
              • Dec 2022
              • hcm
              #26
              HELP ME BIOS EC BM5070 V1.4 (ITE 5576-128)
                • 21922
                https://www.badcaps.net/forum/troubl...before-posting post your laptop serial number
                • tuthanh
                  • Dec 2022
                  • hcm
                  #28
                  legion s7 15ACH6
                  S\N:PF3K62FJ
                  VER:BM5070_V1.4
                    • 21922
                    legion s7 15ACH6
                    S\N:PF3K62FJ
                    VER:BM5070_V1.4
                    EC
                    • Navid_AJR
                      • May 2025
                      • Iran
                      #30
                      Same issue for me. My laptop got a power failure during bios updating and now it won't power on at all.
                      S/N: PF2XWM03
                      Thak you in advance.
                      • peste
                        • 13599
                        • ROMANIA
                        #31
                        S/N: PF2XWM03
                        post the contents of the bios chip even if it is corrupted..
                        • Navid_AJR
                          • May 2025
                          • Iran
                          #32
                          Thanks for the reply.
                          Just to clarify: this laptop has already been through multiple repair shops, and several different BIOS files have been flashed to it — none of them worked. Unfortunately, in the country I live in, getting access to verified BIOS files is very difficult due to various limitations.
                          At this point, I'm only looking for a verified, clean BIOS dump that exactly matches my machine:
                          - Model: Lenovo Legion S7 15ACH6
                          - Serial Number: PF2XWM03
                          If you or anyone else has a known-good dump from a working unit of the same model, I would be truly grateful. Honestly, I had given up on this laptop — but today I decided to give it one last try and reach out here for help.
                          Thanks again for your time and support.​
                          • peste
                            • 13599
                            • ROMANIA
                            #33
                            you have everything you need at post #6..
                            https://www.badcaps.net/forum/troubl...h6#post1824992
                            • za8zak1
                              • Sep 2025
                              • Malaysia
                              #34
                              SN: PF375S3Q
                              Motherboard Model: LENOVO LNVNB161216
                              Bios Version: HACN46WW
                              If possible, may I request the previous BIOS version? Right now, my laptop is unable to detect peripheral devices on both USB-C ports on the right side. I have already tried many things, such as updating drivers, performing a soft reset (holding the button for 30 seconds), and installing a fresh copy of Windows.
                              The odd thing is, I’m still able to use USB-C to charge the laptop with a 100W charger. Also, if I connect a USB-C hub powered by a 100W supply, I’m able to use peripheral devices. However, when in the BIOS settings, the USB-C ports are unable to detect anything.
                              Thanks in advance.
                              • peste
                                • 13599
                                • ROMANIA
                                #35
                                SN: PF375S3Q
                                Thanks in advance.
                                Do you have other USB-C ports? Does it work on those?
                                • za8zak1
                                  • Sep 2025
                                  • Malaysia
                                  #36
                                  I don’t have other USB-C ports on this laptop—only the two on the right side, and both are experiencing the same issue. The USB-A ports at the back are working fine. Since this problem started after the BIOS update, I would like to request the previous BIOS version to check if that resolves the issue.
                                  • peste
                                    • 13599
                                    • ROMANIA
                                    #37
                                    you have everything you need at post #6...
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 932
                                      • Peru
                                      #38
                                      https://download.lenovo.com/consumer...s/hacn39ww.exe
                                      https://download.lenovo.com/consumer...s/hacn42ww.exe
                                      https://download.lenovo.com/consumer...s/hacn43ww.exe
                                      The trick is to rename the download link, sometimes that won't work anymore as Lenovo removes old versions from their website
                                      But I don't think it's a BIOS issue, it may be hardware problem such as dirty/oxidized contacts/moisture on the ports themselves, get a USB-C voltage tester
                                      • madushanka 1234
                                        • Apr 2019
                                        • 69
                                        • sri lanka
                                        #39
                                        sn-PF3B93P9
                                        bm5070 v1.4
                                        MAIN AND EC BIOS NEED..........
                                        PHOTOS ATTACHED..
                                        • peste
                                          • 13599
                                          • ROMANIA
                                          #40
                                          sn-PF3B93P9
                                          bm5070 v1.4
                                          PHOTOS ATTACHED..
                                          Don't post pictures unless asked.
                                          • Thomas Dunlap
                                            Corrupted/Interrupted Bios Update Lenovo Legion S7 15ACH6
                                            by Thomas Dunlap
                                            I have a Lenovo Legion S7 15ACH6 that was interrupted during a BIOS update and is now bricked. Symptoms: fans spin, RGB keyboard lights up, but no display/POST.
                                            The BIOS chip is a Gigadevice GD25LR128. I’m using a CH341A with a 1.8 V adapter. In AsProgrammer I selected GD25Q128 (since GD25LR128 isn’t listed) and successfully made a dump (BiosDump2_pf3eg12j.rar).
                                            My understanding is that I’ll need a known good BIOS dump for this exact model, ideally matched to my laptop’s serial number (PF3EG12J), and that the Windows license key/serial should also...
                                            09-26-2025, 12:45 PM
                                          • grimacelord
                                            by grimacelord
                                            Hello there.
                                            History:
                                            03-15-2023, 03:29 PM
                                            Lenovo Legion S7 15ACH6 Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion S7 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S7 15ACH6 boardview and S7 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                            Lenovo Legion 5 15ACH6 Notebook Specification for Upgrade or Repair
                                            This specification for the Lenovo Legion 5 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ACH6 boardview and 5 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 04:30 AM
                                          • JarJarBinks
                                            Need BIOS BIN for Lenovo Legion 5 15ACH6 Type 82JW
                                            by JarJarBinks
                                            Laptop was powered off during BIOS update. Laptop turns on, keyboards lights up, and then just beeps over and over into infinity until powered off.
                                            Model: Lenovo Legion 5 15ACH6 Type 82JW
                                            S/N: PF30P6DN
                                            Attached is the BIOS dump from the laptop and the latest BIOS update from Lenovo.
                                            I searched and I don't believe this particular bios has been posted. I attempted to the follow directions
                                            on the BIOS guides page but I am brand new to this and the update file doesn't seem to match
                                            the bios dump in size so I am at a loss on what to do to...
                                            01-01-2024, 03:15 PM
