Dell 7710 strange behavior - corupted bios ?
  • pirih77
    • Oct 2020
    • 62
    • Slovenia
    I have a dell with strange behavior. When i connect the chatger the power ligt stays on for abou 2 sec and then shuts of. After 30+sec the fan starts for a while, bun no power light.
    Could it be corrupted bios ?
    Here is the original backup.
    Any help apprechiated.
  • zszahid
    • Jun 2021
    • 35
    • Pakistan
    Re: Dell 7710 strange behavior - corupted bios ?
    check this thread
    https://www.badcaps.net/forum/showthread.php?t=81185
    • pirih77
      • Oct 2020
      • 62
      • Slovenia
      Allready did. But if i understand correctlyfixed bios must be made from original one.
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        allready did. But if i understand correctlyfixed bios must be made from original one.
        try
        SERVICE TAG :- 11V3PC2
        AND FEW MINUTE AFTER FLASH
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Precision 7710
          ​https://www.badcaps.net/donate
          • pirih77
            • Oct 2020
            • 62
            • Slovenia
            Originally posted by qayyum786
            try
            This one worked.
            Thank you!!!
            • pirih77
              • Oct 2020
              • 62
              • Slovenia
              Update:
              Bios from qayyum786 worked (but i could only enter bios. All after that was black screen)
              Bios from hoaca388 works. I can boot to windows. But i have strange problems. When i shut down windows the laptop is dead. Even the power light is off. Power button does nothing.If i replug powerthe laptop starts again. I tryed to update bios with the latest one, but it says it is an unsupported downgrade (even if a see in windows that the current bios is older).
              Any advice ?
                • 22283
                Update:
                Any advice ?
                Does this service tag match the one on the laptop case 11V3PC2
                • pirih77
                  • Oct 2020
                  • 62
                  • Slovenia
                  Yes service tag is 11V3PC2in bios and on the case
                  • qayyum786
                    • Aug 2018
                    • 1959
                    • INDIA
                    yes service tag is 11v3pc2in bios and on the case
                    once more
                    • pirih77
                      • Oct 2020
                      • 62
                      • Slovenia
                      once more
                      Both bioses are working. But looks like there is something wrong with the motherboard. The only way to power it on is to reconnect the charger.
                      Light on power button is working (and i measured the power button and it is ok), but if i press it there is no function. CAnt power or shutdown with the button
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
                      • capoplays
                        Help with BIOS update on Dell G15 5515 after chip replacement
                        by capoplays
                        Hey everyone,
                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                        When I check the BIOS using the F12 menu Flash...
                        10-24-2025, 06:53 AM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
                      • jhanra
                        by jhanra
                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                        11-02-2024, 04:19 AM
