Surface Pro 5 damaged BIOS
  • sorin_mirza
    • Feb 2014
    • 5
    • Spania
    Please can someone take a look at this dump that I extracted from a Surface Pro 5 that doesn't start.
    It seems that the bios chip has some problem because I put other bios IC from a working surface Pro 5 and is starting but touch not working.
    I try to flash the original IC with a dump that I read from the good one and cleaned the Me, but it seems it doesn't start.
  • sorin_mirza
    • Feb 2014
    • 5
    • Spania
    Re: Surface Pro 5 damaged BIOS
    Problem solved. Replaced ME region in the good dump with ME region from original dump.
    Now touchscreen work again.
    • pirih77
      • Oct 2020
      • 62
      • Slovenia
      Surface 5 pro ME Clean
      I have a problem trying to clean ME of a surface 5 pro 1796 because of a non working touchscreen
      Intel FIT gives me an error
      Error 10: Failed to open with processed commands.
      Unable to open file
      I am using the latest version.
      Dump opens in ME Analyzer.
      Can someone check if the dump is OK and help me clean ME
      • pirih77
        • Oct 2020
        • 62
        • Slovenia
        Re: Surface 5 pro ME Clean
        Anyone willing to help.
        I would like to know if my dump is bad, or is there a problem with FIT version
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Use Sorin_mirza's advice:
          Become a Badcaps supporter
          Thanks to all supporters.
          • pirih77
            • Oct 2020
            • 62
            • Slovenia
            When i try to open the dump in Intel FIT it gives me an error
            Dont know if it is FIT problem, or something wrong with the dump.
            • osman68i
              • May 2015
              • 338
              • The Netherlands
              bios with your original posted me
              • pirih77
                • Oct 2020
                • 62
                • Slovenia
                With this one the touch is still not working.
                And the Asset tag ic none, and version of touch firmware 0.0.0.0.0.0.0
                • pirih77
                  • Oct 2020
                  • 62
                  • Slovenia
                  Which version of Flash image tool did you use to open the dump.
                  I cant get it to open anywhere
                  • arashmoayyedizadeh
                    • Jan 2022
                    • 53
                    • Iran
                    surface pro5 1796
                    hello friends
                    this is a surface pro 5 1796 that the touch screen not working after update os
                    the first time the machine boots to windows touchscreen works
                    after you press the power button and machine goes to standby the next time you press power button and touchscreen doesnt work anymore
                    this is my original dump
                    i have tried all the ways i could to clear me but none of them worked and touch didnt work
                    please help me friends
                    thank you very much
                    • peste
                      • Dec 2016
                      • 12763
                      • ROMANIA
                      Re: surface pro5 1796
                      Originally posted by arashmoayyedizadeh
                      hello friends
                      thank you very much
                      did you try this??
                      https://www.badcaps.net/forum/showthread.php?t=104153
                        • Jan 2022
                        • 53
                        • Iran
                        thank you for your time
                        i tried to do that method but i didnt succeed
                        when i drop my original dump in fit tool ish supported is yes and ish powerupstate is enabled
                        as soon as i load clean me from repository ish supported becomes no and ish powerupstate becomes disabled
                        i tried to change them but when i start the build fit gives back errors
                        Error 32: [FitActions] Unable to load ISH image. Image appears to be an Intel image but the Integrated Sensor Hub Signing Policy is set to OEM only.
                        Error 5: [CsmeBinaryGen] Error executing pre-build actions.
                        Error 15: Failed to build.
                        Failed to build!
                        i tried to change ish input file into my original dump but again it gives another error
                        Error 47: [FitActions] Invalid hash provided. The value specified for "OEM Public Key Hash" must be a valid hash other than all '0's or 'F's when loading an OEM signed ISH image.
                        Failed to build!
                        i changed the ishsigningpolicy from oem to intel and the process completed but didnt work on machine
                        • ahkh_72
                          • 103
                          • Iran
                          Surface Pro 5 Loop on logo
                          Hi
                          there is surface pro 5 (1807)
                          MB : M1011229-019 REV 4.3
                          when i power it on , display logo for 3 second and power off.
                          I know that the problem is with the BIOS file, because when I programmed this BIOS (https://www.badcaps.net/forum/showth...highlight=1807)
                          ,the problem was solved, but it does not boot and the touch does not work.
                          Can anyone fix the original bios I attached?
                          Thankful
                          .Today should be different from yesterday.
                            • 20837
                            Re: Surface Pro 5 Loop on logo
                            Originally posted by ahkh_72
                            Hi
                            Post the laptop serial number.
                            • ahkh_72
                              • 103
                              • Iran
                              Originally posted by smdflea
                              post the laptop serial number.
                              rules update for bios requests/offers *avoid banning, read before posting*
                              (1807 256gb 072564481653)
                              • ahkh_72
                                • 103
                                • Iran
                                nobody to help?
                                • albologna
                                  • May 2022
                                  • 27
                                  • italy
                                  I have this SP5 that starts for 2 seconds and then shut down. Checked everything and seems perfect. I think it is a bois fault. Can someone help me?
                                  Flashin a good random bin file from another Surface it starts to UEFI but the touch has no firmware and does not work
                                • Q1999
                                  • Oct 2023
                                  • 18
                                  • Vietnam
                                  surface pro 5 1796
                                  serial number; 056839481853
                                  i5/8/128
                                  The device's charging port was faulty, the charging port was replaced, all functions work fine, only the device's sensor stopped working.
                                  Tried win again, still the same. Need people to help .
                                  This is the original bios file of the device that has not been edited.​
                                  • Vesko356
                                    Vesko356 commented
                                    Editing a comment
                                    Thread merged.
                                    Please use the forum search to find related threads where you can post your request. You're NOT allowed to start a new thread if there's an existing one!!!
                                • danielFAB
                                  • Jul 2016
                                  • 29
                                  • Argentina
                                  Hi all
                                  I have a Surface Pro 5 with corrupted BIOS, turns on, shows logo for 2 seconds and turns off.
                                  I tried another dump from the forum and the device works fine, but without touch
                                  I have tried several times to do ME Clean and always the same result.
                                  The BIOS original is corrupted. Anyone who can give me a hand? integrating a new BIOS
                                  Surface Pro 5 1796 256GB
                                  sn 012914483253
                                  main M1007506-015
                                  Attach
                                  1796_ORI.bin (original corrupted)
                                  Surface_1796.bin (dump another surface, works without touch)
                                  thanks in advance!​
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    Originally posted by danielFAB
                                    Hi all
                                    sn 012914483253
                                    main M1007506-015
                                    Attach
                                    thanks in advance!​
                                    Try
                                    • shadow666
                                      Surface Book 3 1899_TOP Rev 2.0 Bios Dump
                                      by shadow666
                                      hello
                                      i need surface book 3 dump bios
                                      Model : 1899
                                      MB : 1899_TOP
                                      Rev 2.0
                                      Serial : 037248401157
                                      CPU :Core i7-1035G7
                                      Dump Bios problem is no power
                                      Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
                                      Regard...
                                      02-24-2025, 11:01 AM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • kvanta
                                      Surface Pro 9 2038 need bios dump
                                      by kvanta
                                      Surface Pro 9 2038 BB_W MB SRLFP Intel Core i7-1255Usn 0f01juw23133bf need bios dump
                                      Hello, thanks for your reply, well you see I think I might have a corrupted bios because when I power on the surface pro 9 I get the windows logo comes on twice and then it turns off.
                                      I add the native BIOS, thanks!...
                                      08-20-2024, 03:34 AM
                                    • SevenBIOS
                                      Surface 3 BIOS dump for BIOS PW
                                      by SevenBIOS
                                      Hey guys, i have a surface 3 with a bios password which i cannot remember.
                                      I tried to dump the current bios with fptw64.exe thats what it says
                                      C:\Users\Admin\Desktop\bios>fptw64.exe -bios -d surface.bin
                                      Code:
                                      Intel (R) Flash Programming Tool. Version: 9.5.40.1868
                                      Copyright (c) 2007 - 2014, Intel Corporation. All rights reserved.
                                      Error 201: [FPTw64.exe] cannot be run on the current platform.
                                      Please contact your vendor.
                                      I dont know how to continue.. am grateful for help!
                                      EDIT: im...
                                      03-13-2023, 07:42 AM
                                    • Kotp384
                                      Surface book 3 (1907) bios dump
                                      by Kotp384
                                      Hello everyone I really need a BIOS dump of surface book 3 (1907) 25R128jwpq. I just turned off the device and it didn't turn on anymore, it doesn't show any signs of life. Only the charging indicator lights up and goes out when the power button is pressed for a long time. All the voltages on the board are in order, there is a theory that the BIOS is somehow lost.
                                      I will be grateful for any help
                                      07-19-2024, 07:31 PM
