bios asus S532F NEED
  • johansel
    • Feb 2022
    • 34
    • colombia
    good afternoon, I need help with the bios of an asus S532F board model X532FL attached old file
    the equipment does not show image
    Thank you very much for the help
  • hardware1
    • Sep 2021
    • 2927
    • N/A
    Re: bios asus S532F NEED
    Write your Device Serial Number.
    all donations are welcome,
    • johansel
      • Feb 2022
      • 34
      • colombia
      write your device serial number.
      s/n: Kbn0cx17a912484
      • hardware1
        • Sep 2021
        • 2927
        • N/A
        This file is already Configured (Clean) and also the Bios Region is identical with the official one, so it should works fine!
        Where is your Original Backup?
        • johansel
          • Feb 2022
          • 34
          • colombia
          That is the original file of the equipment, only after making an update it stopped giving video
          If you could help me with a new file to discard that is not due to my .bin
          • hardware1
            • Sep 2021
            • 2927
            • N/A
            Try this one.
            • riki_22
              • Jun 2014
              • 63
              • italia
              Hello people,
              this product turns on but from a black screen, I suspect a bios problem, I'll send you the dump attached, can you help me?
              ASUS S532FL-BQ273T
              Serial number: L1N0CX03C27602C
              AS S532F 10510U/2DZ/8G/IT
              • riki_22
                • Jun 2014
                • 63
                • italia
                Originally posted by riki_22
                Hello people,
                ASUS S532FL-BQ273T
                the Main Board is :
                X532FLC REV 2.0
                • dpu
                  • Jun 2015
                  • 5
                  • Magyarország
                  Hello. ASUS S532F bios required. It's not turned on. Attach original content. The serial number is K6N0CX08W007254. Thanks if someone helps.
                  • peste
                    • Dec 2016
                    • 12643
                    • ROMANIA
                    try post #6..
                    • dpu
                      • Jun 2015
                      • 5
                      • Magyarország
                      Hello. I tried. Unfortunately, nothing changes. It cannot be turned on.
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
