Need hp omen 15-dc1000nk bios dump
  • krichtot
    • Oct 2021
    • 20
    • belgium
    Hi, i really need bios dump for DAG3DCMBCC0 rev c (hp omen 15-dc1000nk)
    i need the 16mb and the little 1mb chip dump
    I can't find it anywhere, thanks for helping me
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: Need hp omen 15-dc1000nk bios dump
    Do you have the original backup bios? if yes, upload it here.
    Also write your device Serial Number.
    all donations are welcome,
    • krichtot
      • Oct 2021
      • 20
      • belgium
      I did a backup of both chip
      I don't have them at the moment but tomorrow I will post the dump files
      Thank you
      • krichtot
        • Oct 2021
        • 20
        • belgium
        hi , hardware1 here are the dumps in the attached file thanks.
        S/N : 5CD946BXLH
        • peste
          • 13430
          • ROMANIA
          S/N : 5CD946BXLH
          bios extracted from HP site update..
          DMI 340000 - 3410FF
          KEYWIN A9E000 - A9E03F
          • krichtot
            • Oct 2021
            • 20
            • belgium
            I already tried with that bios from hp still nothing the board has all the power rails no shorts it turn on, fans are spinning but no picture...
            I have the cap lock blinking that's all
            The laptop was working before I wanted to update the bios chip with ch341a because the laptop wont boot on windows properly from then the laptop is dead..
            • peste
              • 13430
              • ROMANIA
              if the bios from post #5 does not work, either you wrote the bios chip with errors or the laptop has other problems.. remove the bios chip from the board before writing or reading... or stick wires between the chip and the programmer.. .check the connection to the bios chip..use these programs..
              https://www.badcaps.net/forum/showpo...6&postcount=10
              https://www.badcaps.net/forum/showpo...04&postcount=7
              • krichtot
                • Oct 2021
                • 20
                • belgium
                Thank you peste for your reply
                I did all those steps so many time with no succes
                I think I damaged the ITE chip when I was reprograming the little bios with the clipper thing without desoldering
                I just purchased a working motherboard from ebay...
                • MDSI
                  HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                  by MDSI
                  I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                  Details:
                  Model : HP OMEN 17-an012nf
                  Motherboard Part Number : DAG3BAMBAF0 REV : F
                  Serial Number (S/N) : 5CD7280D51
                  BIOS chip : Winbond W25Q64VSIQ
                  Programmer : EZP2023+
                  Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                  I already...
                  07-28-2025, 07:11 AM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • JoWed
                  Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                  by JoWed
                  Hello Community,
                  I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                  07-01-2025, 09:32 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  by haitham sharabati
                  Hello engineers 😀,
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  💀 Problem:😅
                  08-07-2025, 04:54 AM
