Need hp omen 15-dc1000nk bios dump
  • krichtot
    • Oct 2021
    • 18
    • belgium
    Hi, i really need bios dump for DAG3DCMBCC0 rev c (hp omen 15-dc1000nk)
    i need the 16mb and the little 1mb chip dump
    I can't find it anywhere, thanks for helping me
  • hardware1
    • Sep 2021
    • 2887
    • N/A
    Re: Need hp omen 15-dc1000nk bios dump
    Do you have the original backup bios? if yes, upload it here.
    Also write your device Serial Number.
    all donations are welcome,
    • krichtot
      • Oct 2021
      • 18
      • belgium
      I did a backup of both chip
      I don't have them at the moment but tomorrow I will post the dump files
      Thank you
      • krichtot
        • Oct 2021
        • 18
        • belgium
        hi , hardware1 here are the dumps in the attached file thanks.
        S/N : 5CD946BXLH
        • peste
          • Dec 2016
          • 12230
          • ROMANIA
          S/N : 5CD946BXLH
          bios extracted from HP site update..
          DMI 340000 - 3410FF
          KEYWIN A9E000 - A9E03F
          • krichtot
            • Oct 2021
            • 18
            • belgium
            I already tried with that bios from hp still nothing the board has all the power rails no shorts it turn on, fans are spinning but no picture...
            I have the cap lock blinking that's all
            The laptop was working before I wanted to update the bios chip with ch341a because the laptop wont boot on windows properly from then the laptop is dead..
            • peste
              • Dec 2016
              • 12230
              • ROMANIA
              if the bios from post #5 does not work, either you wrote the bios chip with errors or the laptop has other problems.. remove the bios chip from the board before writing or reading... or stick wires between the chip and the programmer.. .check the connection to the bios chip..use these programs..
              https://www.badcaps.net/forum/showpo...6&postcount=10
              https://www.badcaps.net/forum/showpo...04&postcount=7
              • krichtot
                • Oct 2021
                • 18
                • belgium
                Thank you peste for your reply
                I did all those steps so many time with no succes
                I think I damaged the ITE chip when I was reprograming the little bios with the clipper thing without desoldering
                I just purchased a working motherboard from ebay...
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Dani Rahal
                  hp omen 17-cb0247ng bios
                  by Dani Rahal
                  Hi can some one help me plz
                  i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
                  i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
                  the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
                  i have the orginal bios if some one can see what the problem or...
                  05-30-2025, 09:11 AM
                • DavidJocic
                  Omen 15-dc1056nf (Need Dump Bios or something ) Thanks :(
                  by DavidJocic
                  Hello everyone firstly i'm thankfully if someone can help me if not i'm very stupid i have use ch341-a to flash my bios when i was deleted chip and loose my original backup, then the problem comes my laptop won't start only red light blinking without boot and without screen and fans but electricity is there in light close to charger. Chip was not damaged cause via application works when i want to update. Probleme is next i even tryed to download official bios from hp and put there informations of my serials numbers which is : 5CD938GPG1 (with HxD ). My model is with chip name winbond 25Q128JVSQ...
                  04-28-2025, 12:54 PM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • grimacelord
                  Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                  by grimacelord
                  This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                  Motherboard model number: DA0PAMB46A1 REV: A
                  Secondary motherboard model number: 0PAB
                  SKU: 685K4UA
                  Serial number is: 5CD3223BJP
                  Recently reflashed this laptop with latest BIOS and once...
                  05-07-2024, 08:06 AM
