x13 gen1 unlocked keyboard touchpad not working with windows11
  • couillu76
    • Jan 2022
    • 39
    i have recently unlocked the bios on my x13 gen1 since i have this problems
    error 2202 product name is invalid, i have been trying and trying with the lonovo tool and different versions nothing work, error 2202 all the time
    the second problem is my keyboard and my touchpad, they work in the bios but at soon I'm booting on windows 11 they stop working but i can plug a keyboard and a mouse, check my drivers there ok , i also reinstall them few time , is it related to the bios ? please i need help
  • master3112
    NM-C741 Lenovo L15 Gen 1 Touchpad and Trackpoint don´t work
    by master3112
    I have a Lenovo L15 Gen 1. The touchpad and trackpoint on the device are not working. Not even in BIOS, so it's not a driver issue. The touchpad is enabled in BIOS. When I run Lenovo Diagnostics for Windows, the touchpad is not even recognized. I have already updated BIOS, without success. VCC is present on the touchpad connector.
    Does anyone have any ideas?
    10-07-2025, 07:01 PM
  • B2L_Repairs
    Macbook A1706 touchpad and keyboard not working. Please help
    by B2L_Repairs
    Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
    10-09-2023, 04:56 AM
  • claws77
    lenovo flex5-14itl05, touchpad water damage
    by claws77
    last night i dropped some liquid over my laptop touchpad, immediately stopped using and tried to dry it up.
    the touchpad misclicks, sometimes stops working altogether
    i have removed the touchpad assembly cleaned it with alcohol and brush and cotton buds.
    can i fully disassemble the touchpad assembly as i suspect some liquid is still lurking inside the trackpad.​...
    07-15-2024, 07:34 PM
  • MichelinMan
    CF-20 Toughbook (mk1) Trackpad/Touchpad and USB ports not working
    by MichelinMan
    Hey guys,
    Just purchased a CF-20 (mk1) supposedly was all working. However, the seller had done a fresh install of windows 10 but did not install any driver. Seller was adamant the trackpad/touchpad was working.
    The touchpad/trackpad does not work. No led lights near the trackpad. The keyboard works, the USB 2 port on the base does not work, The USB 3 ports will recognise a USB 3 flashdrive but did not recognise a USB mouse. The ethernet port on the keyboard section works.
    The USB 3 port on the actual tablet section works with no issues.
    07-18-2023, 08:12 AM
  • Scenic
    Thinkpad T14 Gen1 (Intel ; NM-C931) fan not working
    by Scenic
    Got a weird issue with a Thinkpad T14 Gen1 motherboard out of/currently still in a scrap machine (cracked display, damaged case, otherwise working) that I bought to rob parts from for another thinkpad.
    The motherboard generally works (booted into a test install of Win10 with no issues), however the fan never spins during use. It does spin for about 2 seconds right after turning on the laptop, but after that, never again.
    Just to double-check, I've tried a different (known working) fan from a T14 Gen2 and it does the exact same thing when plugged into this mobo, and the fan from...
    06-29-2025, 04:02 PM
