Thinkpad T14 Gen1 (Intel ; NM-C931) fan not working
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Got a weird issue with a Thinkpad T14 Gen1 motherboard out of/currently still in a scrap machine (cracked display, damaged case, otherwise working) that I bought to rob parts from for another thinkpad.
    The motherboard generally works (booted into a test install of Win10 with no issues), however the fan never spins during use. It does spin for about 2 seconds right after turning on the laptop, but after that, never again.
    Just to double-check, I've tried a different (known working) fan from a T14 Gen2 and it does the exact same thing when plugged into this mobo, and the fan from this T14 Gen1 works perfectly fine in a T14 Gen2, so the fan itself definitely isn't the problem (cause that would be a simple fix, can't have that lol)
    It obviously overheats in no time (80-100C within minutes), so as a temporary workaround I've disconnected the PWM wire from the fan plug for now so it always runs at full speed, but that obviously isn't a proper fix.
    This was just to do stability testing to verify that the board works otherwise (everything other than the fan issue).
    What bothers me is that the fan isn't completely dead as it spins for a couple seconds after powerup, so it does get a PWM signal, and from the little bit of research I've done the PWM signal to control the fan seems to come from an embedded controller (MEC1663). If that's what's failing I'd have no way to deal with this, hardware wise.
    I also don't get a fan error in BIOS for some reason, even with no fan plugged in at all. That doesn't seem right either.
    If anyone has experienced (and ideally fixed) a similar issue or has any ideas on where to start, that would be greatly appreciated. At this point I'm not even sure whether it's a hardware issue or maybe EC firmware (!? ; botched mod attempt maybe?).
    T14 Gen1 (type 20S0), i7-10510U, 16GB soldered RAM, no dGPU, NM-C931 rev 1.0 motherboard
  • Acnologia
    Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
    by Acnologia
    Hello to all members of badcaps.
    Another brainstorming that i have been messing with for months as a side project.
    Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
    I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
    Step 1.
    Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
    Machine > Doesn't give display it's really dim.
    Step 2.
    Use the same...
    11-05-2025, 04:02 AM
    Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-06-2024, 11:40 AM
