HP EliteBook 640 G9 Bios password
  • babydoll8867
    replied
    Originally posted by minhdigital
    Send to you
    thank you very, very much, it solved all the problems!!!!
  • minhdigital
    replied
    Originally posted by babydoll8867
    can you help me please with a clear ME for my original file? i found the repository for ME 16 but not for PMC, PCHC and PHY.... thank you!
    Send to you
  • babydoll8867
    replied
    Originally posted by hoaca388
    Try clear ME .
  • hoaca388
    replied
    For two days i am trying to get the notebook to work as it should. the password is gone for sure but i am getting constnt errors. it boots every other time. when it doesn't, it seems like it doesn't see the ssd. in device manager i had an I2C "cannot start" error, after that "intel smart sound technology OED" with "FW did not sent FW ready notification" and when i try to update the bios, it doesn't do it. the boot fails, restarts then enters windows. i even wrote the original bios file back but still same errors. what to do next please?
    Try clear ME .
  • ravenmx
    replied
    Originally posted by ravenmx
    i have the same problem, i use bios fix from hoaca388 but lose the ssd boot, anny solution?
    i restore the ec original... boot and restard ... same... problem, i restore main bios original and restard this works, finally update the bios from hp site and works , thanks you,
  • ravenmx
    replied
  • babydoll8867
    replied
    HP EliteBook 640 14 inch G9 Notebook PC
    Serial_5CD3221JW9
    Product_4D0Z0AV
    Build Id_22WWRTDZ601#SABE#DABE
    Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAeMfPgSguhKjhk8mEmVn7nVpDpFpVpnpqprqjqz.dY
    CT Number_6MBME0KWYI3A4N
  • ravenmx
    replied
    [QUOTE=hoaca388;n3663960]
    CT Number_6MFDQ0DTZHFKYL
    Serial_5CD3029GQN
    Sku_7C244UC#ABM
    Build Id_22WWRTCT601#SABM#DABM
    Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPgSguhKjhk8mEn7nVpDpFpVpqqjqz
    thanks but not working ... they have pass..... please check again. thanks you
  • babydoll8867
    replied
    Serial_5CD3221JW9
    Product_4D0Z0AV
    thank you very much,it worked
  • hoaca388
    replied
    Hi, can you please help me unlock this 640 g9? sn4D0Z0AV
    thank you!
    Serial_5CD3221JW9
    Product_4D0Z0AV
  • babydoll8867
    replied
    thank you!
  • hoaca388
    replied
    please help to remove password
    hp elitebook 640 g9
    id 7c244uc#abm
    sn 5CD3029GQN
    POST 355 and 416 not working
    Serial_5CD3029GQN
    Sku_7C244UC#ABM
    Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPgSguhKjhk8mEn7nVpDpFpVpqqjqz.5E
  • AHSAN TARIQ
    replied
    post 355 and 416 i see this because forum are updated like database problem
    here i can remove the password ry and update me
  • ravenmx
    replied
    hp elitebook 640 g9
    id 7c244uc#abm
    sn 5CD3029GQN
  • Barboska
    replied
    Originally posted by rex98
    i'm sorry it didn't work coz i haven't noticed its a two bios version for this model. its U75 and U86.
    the post number # 355 is U86
    this is the new one for U75
    HP EliteBook 640 14 inch G9 U75
    The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU and put your original DMI.
    Invalid File Specified
    Please reupload files
  • babydoll8867
    replied
    hi,
    do you have any idea why i can't download the files from your post#355 and #416? it says "invalid file specified".
    as the matter of fact i can't download anything, tried it, same error...
    thanks in advance!
  • eren123
    replied
    Ok, flashed both SPI and EC using the files from rex98 at #412 and it worked. Thanks!
  • eren123
    replied
    Originally posted by Bios Cracker
    Try and Update.
    Still asks BIOS password
  • Bios Cracker
    replied
    Originally posted by eren123
    Can you help me to remove the Bios password please?
    Elitebook 640 G9
    S/N:5CD4071JQT
    PROD_ID:4D0Y7AV
    Try and Update.
  • eren123
    replied
    Elitebook 640 G9
    S/N:5CD4071JQT
    PROD_ID:4D0Y7AV
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • tlindi
    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
    by tlindi
    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
    Ack
    Ack
    01-30-2025, 04:26 AM
  • Nopslide
    by Nopslide
    04-01-2024, 04:27 PM
  • Wutru
    HP Elitebook 820 G4 BIOS repair assistance required
    by Wutru
    Hi guys,
    If someone would be able to provide some expertise, I'd be very grateful.
    BIOS Corruption - Cause
    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
    09-06-2025, 10:32 AM
