HP Elitebook 845 G8
  • Gabriel7
    • Mar 2014
    • 7
    • Greece
    here you are
    • hoaca388
      Badcaps
      • Jan 2022
      • 11420
      • Viet Nam
      Originally posted by Gabriel7
      here you are
      Name of chip do you read ?
      • Gabriel7
        • Mar 2014
        • 7
        • Greece
        You mean winbond 25q256jv ?
        • hoaca388
          Badcaps
          • Jan 2022
          • 11420
          • Viet Nam
          If it's this chip, it can't be 184KB. Read the chip again.
          • Gabriel7
            • Mar 2014
            • 7
            • Greece
            Hello again. I initially flashed the corrupted bios with one that was uploaded in the chat (W25Q256FV@WSON8 8X6_20230112_142817 U367 MAIN). When I did this, the machine from 6 caps blinking went to turn on -but fans stayed fully rpm and that's it. I reflashed it with T82_01130100.bin and now doesn't turn on and caps flashes 7 times. I don't know if there is any hope. I have only the serial number of the machine.
            • Gabriel7
              • Mar 2014
              • 7
              • Greece
              #26
              Hello and sorry for the repost. I have a same and operational hp 845 g8 in my hands. Is there any software for backing up his bios and then you to make the proper modifications with the serial number?
              • Gabriel7
                • Mar 2014
                • 7
                • Greece
                #27
                I don't know if this helps
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11420
                  • Viet Nam
                  #28
                  Read
                  • Gabriel7
                    • Mar 2014
                    • 7
                    • Greece
                    #29
                    OK uploaded.
                    • Guest
                      Elitebook 850 G5 BIOS bricked
                      by Guest
                      I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                      I assume the BIOS update failed, so I searched for the BIOS chip.
                      I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                      However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                      Can the corrupted...
                      03-24-2025, 01:21 AM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • moshu
                      HP EliteBook 755 G4 bios password locked
                      by moshu
                      Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                      I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                      Can you please help to remove the password?
                      after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                      HP EliteBook 755 G4
                      ProdID: W5Q98AV
                      SN: 5CG7524BY4...
                      02-01-2025, 06:59 AM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • idegenerated
                      HP 800 G6 Locked BIOS (with Sure Start)
                      by idegenerated
                      Thanks for your help in advance. I have an HP 800 G6 that has "Protected by HP Sure Start" on boot. It has a locked BIOS that I'm trying to remove with RCUnlocker, but even after unlocking it and reflashing, it doesn't appear to work. The password is still prompted when I attempt to enter the BIOS.
                      Using NeoProgrammer in Windows and a CH341a I was able to read two 16MB BIOS chips, a GD25Q127C and a GD25Q128x like this thread here: https://www.badcaps.net/forum/troubl...-desktop-mothe...
                      03-11-2024, 09:49 PM
