HP Elitebook 845 G8
Re: HP Elitebook 845 G8
Bios for AMD cpu have no ME region.Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donate -
hello all friand please i need your help bios locked Elitebook 845 G8Attached Filesif you find these attachements useful please consider making a small donation to the site
here try it and give me feedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
hello guys, hope your festive seasons are well.
kindly help me fix my bios, am pretty sure my bios region has a problem.
the machine powers on then brings the bios update screen and it goes off.
its a repetitive sequence
i think machine was updating and it lost power
sn:5cg1243tq1
hp elitebook 845 g8
attached is the backupAttached Filesif you find these attachements useful please consider making a small donation to the site
Here you arehello guys, hope your festive seasons are well.
sn:5cg1243tq1
hp elitebook 845 g8
https://www.badcaps.net/donateComment
hi, can you help fix my 845 G8 (AMD)?
SN:5cg13220IKAttached Filesif you find these attachements useful please consider making a small donation to the site
HP EliteBook 845 G8_AMDAttached Filesif you find these attachements useful please consider making a small donation to the site
hi, can you help fix my 845 G8 (AMD)? NO DISPLAY
LANCIA13/Grizzly2.0-6050A3234201-MB-A0 (A1)
SN#5CG2433YC2
Proid 54W37UP#ABAAttached Filesif you find these attachements useful please consider making a small donation to the site
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
hi, can you help fix my 845 G8 (AMD)? erro endpoint security controller problem
LANCIA13/Grizzly2.0-6050A3234201-MB-A0 (A1)Attached Filesif you find these attachements useful please consider making a small donation to the site
Endpoint security controller problem.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi, can someone help me with the BIOS of the HP Elitebook 845 G8, it turns on but doesn't give an image, thanks!!
mainboard: lancia13/grizzli 2.0-6050a3234201-mb-a1
ProdID: 61H99UC#ABA
SN# 2TK23001Y1
HP EliteBook 845 G8 Notebook PC Bundle (61H99UC)Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, thanks for the help. I programmed the BIOS, but the same error persists. I turn on the laptop, but only the fan spins quickly and it still has no imag and the caps lock doesn't work. If I remove the memory, the laptop beeps. Could the problem be caused by something else?Comment
Maybe !
Hello, thanks for the help. I programmed the BIOS, but the same error persists. I turn on the laptop, but only the fan spins quickly and it still has no imag and the caps lock doesn't work. If I remove the memory, the laptop beeps. Could the problem be caused by something else?↵
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
by Lexsmash85Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...-
by piratiHello everyone,
by moshuHi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
I've read the 16MB chip and patched using RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
Can you please help to remove the password?
after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
HP EliteBook 755 G4
ProdID: W5Q98AV
SN: 5CG7524BY4...-
- Loading...
