need to bios dell 7501
  • phamduy221
    • Jan 2021
    • 54
    • vietnam
    Dell inspiron 15 7501, 19711-1
    Original bios error, I have reloaded and now the computer is having problems
    can't get out of factory mode, slow up. Can you guys help me thanks a lot.
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: need to bios dell 7501
    Can you just specify which one is your original bios?
    Also write your Service Tag, how many bios chips on your board and what is written on it.
    all donations are welcome,
    • phamduy221
      • Jan 2021
      • 54
      • vietnam
      Service Tag: F2RW663
      BIOS ERROR IS ORIGINAL BIOS DOESN'T POWER ON.
      BIOS OK I FIND IT, THE MACHINE IS ON SCREEN BUT THE ERROR CAN'T GET OUT OF MANUFACTURER MODE, MACHINE UP TO SCREEN SLOW, CANNOT ENTER Service Tag NUMBER
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        The files in the compressed "bios error" isn't your original bios, each file is from different device and also messy.
        The files in the compressed "bios ok" is already Configured, so I just change the Bios Region. try those files and let me know.
        • phamduy221
          • Jan 2021
          • 54
          • vietnam
          the files in the compressed "bios error" isn't your original bios, each file is from different device and also messy.
          The files in the compressed "bios ok" is already configured, so i just change the bios region. Try those files and let me know.
          thank you, i tryed it but it light on and off always not on the screen
          • phamduy221
            • Jan 2021
            • 54
            • vietnam
            I have been reading bios from the running machine but when loading to this machine it up up to the blue red blue screen. You can renew it
            • hardware1
              • Sep 2021
              • 2946
              • N/A
              Try.
              • phamduy221
                • Jan 2021
                • 54
                • vietnam
                Try.
                Excuse me I just tried, THIS BIOS SHOULD UP TO THE RED GREEN SCREEN
                • phamduy221
                  • Jan 2021
                  • 54
                  • vietnam
                  You can clean for me this file
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12272
                    Your Inspiron 7501
                    • phamduy221
                      • Jan 2021
                      • 54
                      • vietnam
                      Originally posted by hoaca388
                      Your Inspiron 7501
                      Thank you, this bios works fine but can't enter the svtag number, can't exit the manufacturer mode, please help me
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12272
                        Alt + F
                        • phamduy221
                          • Jan 2021
                          • 54
                          • vietnam
                          Alt + F
                          Press alt+F but when you turn it off and on again, it will go back to the original factory export mode
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12272
                            The DMI information is already in the file I posted, that is, there is a sevice tag number, you want to replace it with another number ? Or the file you posted is not the original machine file ?
                            • phamduy221
                              • Jan 2021
                              • 54
                              • vietnam
                              it doesn't have the svtag number, I can read the bios from the running machine and it doesn't have the svtag number
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12272
                                OK. using this file.
                                • phamduy221
                                  • Jan 2021
                                  • 54
                                  • vietnam
                                  thank you, i tried this file but i can't enter the svtag number and exit the producer mode
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12272
                                    A difficult case.
                                    • phamduy221
                                      • Jan 2021
                                      • 54
                                      • vietnam
                                      Your sevice tag number is... ?
                                      ST: F2RW663
                                      EX: 32819518011
                                      it seems this new dell can't add the svtag number first, i've loaded 10-11 and it does the same.
                                      i have this file that can add svtag number and exit from producer mode you can check it out
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12272
                                        ST: F2RW663
                                        EX: 32819518011
                                        Try older vesion.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • jhanra
                                          by jhanra
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
